sputtering at cruseing speed . - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
  • 1 Post By Birdhunter02
  • 1 Post By Vulcan2000
  • 1 Post By Okievulcan43!
post #1 of 7 (permalink) Old 12-23-2016, 10:53 AM Thread Starter
Okievulcan43!'s Avatar
1993 Vulcan 750 , having problem at cruseing speed no problem going thru the gears , great power. As set speed to cruse start getting a acts like running out of gas , as soon as advance throttle it goes away . Just had carbs rebuilt and new diaframs installed . Could it be electrical ?
SOLVED , fuel vent on gas cap plugged
Okievulcan43! is offline
post #2 of 7 (permalink) Old 12-23-2016, 12:39 PM
check the carb vent hose(s). should be in 'dead' air.
stock config they (1 each carb) go to a 'T' fitting, then from there to the right ear. Make sure the end of the hose is cut at 45 degrees to allow proper venting.
if ear shaved, place end of same hose someplace in dead air (under tank, top of frame rail works well, as does the extra fitting on the cover for the gas gauge)
michiganteddybear is offline
post #3 of 7 (permalink) Old 12-23-2016, 05:38 PM
Mod
Birdhunter02's Avatar
also known as POGS. Phantom out of gas syndrome. As MTB just said, vent hose in rt ear. Should fix it.
Okievulcan43! likes this.
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is offline
post #4 of 7 (permalink) Old 12-23-2016, 06:15 PM
2000 VN 750 Senior Member
Excellent first post and introduction but happy holidays just the same. x2 on the POOGS. More information can be found on this subject by doing a search of that particular subject.
All kidding aside, please do an introduction under the Newbie Check-In heading soon so we know a little more about you and can give you more specific information geared to your particular mechanical experience.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #5 of 7 (permalink) Old 12-24-2016, 10:26 AM Thread Starter
Ok thanks sounds simple enough to check . May take a few days as it is raining here in Okla. Will give update as soon as I can .
post #6 of 7 (permalink) Old 12-28-2016, 02:12 PM Thread Starter
Finally got around to checking vent hoses , everything looks good . Still have same problem , anything else to check ?
post #7 of 7 (permalink) Old 12-29-2016, 01:32 PM Thread Starter
OK ! Thanks for the advise found the problem . Cleaned fuel tank cap , guess the vent was plugged .Now to just ride the h-ll out out it
Gaz73 likes this.
