Sidecar Fitting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 08-11-2005, 10:18 PM Thread Starter
Red face Sidecar Fitting
Wanting to know where the axle centre should be for the sidecar wheel in relation to the rear wheel of motorcycle?
Plus set up of sidecar wheel as per toe-in to bike?
I am only getting 2000 miles from the wheel tread I feel the excessive wear is due to wheel alignment and position of sidecar in relation to the motorcycle.
Thanks for any help
Andrew
Andrew is offline
post #2 of 2 (permalink) Old 08-12-2005, 07:30 AM
Search Goddess
Dianna's Avatar
Re: Sidecar Fitting
It helps if I know which sidecar you have. I run with a Velorex 700 sidecar and the 562 or 565 velorexs would align the same since they all run off the same frame. Misalignment will chew up your tires, your front tire as well as your sidecar tire.
Couple of references for starters..
http://scooter.sidecars.home.comcast.net/alignment.htm
http://www.lap.ttu.ee/xj600/ural/HowToRide.pdf#search='Sidecar%20alignment'
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
