New life, old bike [needs love] - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 06-07-2016, 12:04 AM Thread Starter
LOTTO's Avatar
The 750 I bought last week has been sitting a few years so today I pulled the plugs splashed a little oil in to lube the rings dropped a battery in and turned her over.
I got 2 carbs with the bike neither of which were actually on the bike.
I need all new vacuum hoses, any ideas where to get them from she's an 86'.
LOTTO is offline
post #2 of 22 (permalink) Old 06-07-2016, 12:32 AM
Auto parts store.
You may end up removing half or more of them anyways. Look into marbling / coastering.
post #3 of 22 (permalink) Old 06-07-2016, 03:23 AM Thread Starter
LOTTO's Avatar
Who sells the coasters and are they the same for all years
LOTTO is offline
post #4 of 22 (permalink) Old 06-07-2016, 03:32 AM
Search Ebay....you should find several available.
And yes, they are all the same 1985-2006.
post #5 of 22 (permalink) Old 06-07-2016, 10:03 AM Thread Starter
LOTTO's Avatar
Good deal thanks
LOTTO is offline
post #6 of 22 (permalink) Old 06-07-2016, 10:10 AM
IF you want to save money instead of coasters or for temporary, you can remove all the emission hose/junk and just cap off the fittings off reed valves.
gidaeon is offline
post #7 of 22 (permalink) Old 06-07-2016, 10:17 AM Thread Starter
LOTTO's Avatar
Bike came with 2 sets of carbs. Both off the bike and is missing some of the hoses and the hoses that are there are in pretty rough shape. So I think the coasters and ear shave might actually save me some money.
The question is to jet or not to jet I've seen it both ways on here with stock exhaust.
LOTTO is offline
post #8 of 22 (permalink) Old 06-07-2016, 11:24 AM
every bike is different. some (such as me) have been ok without a rejet, using stock exhaust.
others have needed rejet..
michiganteddybear is offline
post #9 of 22 (permalink) Old 06-07-2016, 11:50 AM
Yep. Get it running with stock jets first and check plugs after adjusting.
IMO the filters you choose could slightly impact need for a slight step up. I rejetted after lean plugs (was rich before ear shave) but with less of an increase less than most recommend on here.
I think going 15% up on fuel delivery for mains sounds extreme for stock exhaust but others say it worked. I went for 40/138 no shims (stock was 38, 132) which is 5% up on slow pilot and like 5% on main.
I am selling a complete rejet kit I didn't use in multiple sizes. Good luck getting her going. Can't imagine replacing carbs with stock intake - so easy when shaved.
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #10 of 22 (permalink) Old 06-07-2016, 12:00 PM Thread Starter
LOTTO's Avatar
I'm not even sure if the carbs I have are original jets or not one carb is complete the other is missing needles.
I've got all the hoses out and ears off suppose I'll hack saw the air box to remove.
Anyone used the emgo pods instead of the k and n so much cheaper don't want to dump a boat load of money in it before she purrs.
LOTTO is offline
