Grip Glue...??? Super Glue OK...??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 09-07-2008, 11:27 AM Thread Starter
Question Grip Glue...??? Super Glue OK...???
My left grip slooowly works its way toward off, and I checked on glue and was told by a shop Mech. that super glue worked... Has anyone used super glue on grips...??? I was thinking that I might take the edge of a file and sort of rake the bar end a bit to help with the slick chrome finish and use super glue on it...
What do y'all think...???
post #2 of 18 (permalink) Old 09-07-2008, 11:40 AM
750Doug's Avatar
Super glue would probably work very well I'd think.
I use a light coat of hair spray on mine. Slides on wet, and dries firm. And if/when they need to come back off, there's no "drama".
750Doug is offline
post #3 of 18 (permalink) Old 09-07-2008, 11:45 AM
Glenn M's Avatar
What Doug said, Hair Spray
Glenn
1985 VN700
Saddle Bags
Small Sport Windshield
R/R moved
Home built coasters
Kaw touring front fender
1990 Fuel tank
Kenda Kruz 110/90-19 & 170/80-15 tires
NGK Iridium plugs
NGK plug caps and 7mm copper core wires.
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #4 of 18 (permalink) Old 09-07-2008, 11:46 AM
Search Goddess
Dianna's Avatar
The golfer grip tape also works well just in case you don't have any hair.. spray
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #5 of 18 (permalink) Old 09-07-2008, 12:42 PM
Scoop's Avatar
I think Dianna just insulted every man over 50 . . .
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #6 of 18 (permalink) Old 09-07-2008, 12:49 PM
Search Goddess
Dianna's Avatar
*LOL* I said hair spray
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #7 of 18 (permalink) Old 09-07-2008, 01:25 PM Thread Starter
Oh well, I had super glue so I used it... I'll let y'all know how it works out, I'm not a big fan of super glue, I've had more to do with epoxies... It may be better than I thought though... I used to use hair spray on bicycle grips and it worked pretty good, but I didn't think it was great...
Thanks Folks and have a good one...Old Dog...
post #8 of 18 (permalink) Old 09-07-2008, 02:20 PM
Only trouble with superglue is....IMO... it could make removal a little difficult if/when the grips need changed. Especially if you roughed up the bars with a file (or anything really)
Ya may need to use a file again to remove residue if ya did roughen up the bars.
post #9 of 18 (permalink) Old 09-07-2008, 02:45 PM
Yeah, I hate to be the one who has to remove those grips later..
Guess it matters how much super-glue you use. I have always had good luck with hairspray, or clear acrylic paint. (At one point in my life I had no freindly sourse of hairspray, so the clear laquer took it's place.
Alot of times I used nothing at all...depends on the grip.
A thin line of superglue down the length of the bar will be easier to remove than brushing on the entire surface. I would not "rough up" the bars with a file however as you'd be taking off the chrome and enabling rust to form.
post #10 of 18 (permalink) Old 09-07-2008, 04:15 PM
cm4cm5's Avatar
when i changed my stock grips to foam grips a couple years ago...i did not use enything at all. they were very tight, and still are..i check them when i do my preride checks just to make sure they wont slide while riding. i have some super glue in my tool bag to make repairs if they do come loose.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
