Vulcan 2007 500ltd stopped working following these cirumstances: - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-01-2016, 06:19 AM Thread Starter
Hello, I bought a used vn500 '07 with 11k miles 6 months ago, fixed up everything two detailed inspections discovered, changed the battery and an hour ago i drove to the diner with choke on, as i turned off the bike and left with the keys after 5 yards, a huge explosion was heard, i'd say louder than a backfire which I never had on this bike before. I went into the diner, 30 mins later I go out, start the bike, since it was still warm, i put choke off after 20 yards, it goes smoothly, i go toa friends place for half an hour, as I leave there and attempt to start the bike: a) ignition lights and everything goes on fine, as I click the starter it CLICKS and everything goes off, I try the key back and forward again, lights go fully on, not low, not blinking, butstarter turns everything off, after that I kept moving the key back and forward, it turned on the lights only occasionally, but eventually stopped fully, again, without them dieing, so questions: a) could whatever happened be linked to choke on driving an hour before? b) could the explosion an hour before made a mess somewhere? c) battery or contact suddenly messed up after 6 months of use?
Regards, Alex
faca82 is offline
post #2 of 3 (permalink) Old 06-01-2016, 09:12 AM
Why were you riding with the choke on?
post #3 of 3 (permalink) Old 06-01-2016, 12:02 PM
Expendable newbie
evulcannibal's Avatar
My initial guess would be an electrical issue.
Check grounding wires. Might also be the ignition switch.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
Tags
battery , choke , explosion , ignition
