Reading my plugs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Chris and Shim
post #1 of 6 (permalink) Old 05-27-2016, 02:53 PM Thread Starter
Reading my plugs
Take a look my plugs. Setup is earshaved via k&n pods, reed valves are capped off -STOCK jets. Pretty sure this indicates mild lean right? Runs fine.
With flash
gidaeon is offline
post #2 of 6 (permalink) Old 05-27-2016, 02:58 PM
Looks a bit sooty, but yeah, lean. Been using iridium plugs for so long I forgot what regular ones looked like...
post #3 of 6 (permalink) Old 05-27-2016, 03:05 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
My iridium plugs are supposed to get here today. Which means I'll switch them tonight. I'm interested in seeing the business end of my now-installed plugs since they've never been out of the bike.
gidaeon likes this.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Chris and Shim is offline
post #4 of 6 (permalink) Old 05-27-2016, 05:42 PM
The "super white" do appear to be too lean. What is the actual gap on the plugs? I run iridium also but that doesn't mean the others won't work just fine. I forgot how low your bike's mileage was.
No Brain - No Pain. I measure a man by the good he does for others, not his mistakes.
Green1 is offline
post #5 of 6 (permalink) Old 05-27-2016, 07:21 PM Thread Starter
I will add the ngk iridium plugs once i get the jets and adjusment figured out for sure.
These plugs were not pulled after load/throttle shutoff but after idling.
One cylinder seems much sootier. What causes that anyway?
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #6 of 6 (permalink) Old 05-28-2016, 12:47 AM
I've got my original ones out (a little over 10,600 miles) and they look similar to yours, except for the sooty one. I did take some pics but this computer just recently switched to Windows 10 and I can't seem to find a "My Computer" portion. I'll have to figure this out as to how to download pics. But anyway, I suppose mine is a bit lean also.
Luggage rack
