Looking for HELP! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
  • 1 Post By Thorn
  • 1 Post By shark88
  • 1 Post By WilliamTech
post #1 of 9 (permalink) Old 05-26-2016, 10:31 AM Thread Starter
Looking for HELP!
At the end of a quick 20 mile ride the other day my 2002 750 lost power and started to backfire, lost power and wouldn't respond when giving it gas. Now when I start it (clutch open) it'll barely hit 1000 RPM, it'll rev if given gas but backfire allot. The oil light never came on and it ran at speed fine until that last mile. Again I'm no mechanic but am looking for some thoughts to tell a mechanic, and is something like this normal DURING a ride or more frequent when trying to restart. Any thoughts would be greatly appreciated.
firstbike is offline
post #2 of 9 (permalink) Old 05-26-2016, 11:30 AM
Clogged fuel line ? ? ? ? - -
post #3 of 9 (permalink) Old 05-26-2016, 11:53 AM
TOTALLY spitballing here, but what would happen if one of the ignition coils went bad?
Would the fuel make it through the non-firing cylinder and cause backfiring when the engine was up to temp?
WilliamTech likes this.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #4 of 9 (permalink) Old 05-26-2016, 11:54 AM
Expendable newbie
evulcannibal's Avatar
My guess would be air leaks? Maybe one of your vacuum lines or air lines got damage or became undone. Might want to check the intake boots and seals around the carbs. Also might want to check exhaust for leaks.
Even though you're not a mechanic, it might be good to do a quick visual inspection to see if there is anything loose or out of the ordinary. To check for air leaks, some people light up a cigarette and hold it up to the carbs or area of interest to see if the smoke is disturbed. Can also use incense sticks if you're not a smoker.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #5 of 9 (permalink) Old 05-26-2016, 11:56 AM
Also sounds like it could be the POOGS (Phantom out of gas syndrom), or possibly a loose ground or battery connection.
Paulywog likes this.
post #6 of 9 (permalink) Old 05-26-2016, 12:41 PM
Yeah, first thing I'd check is if the carbs are getting fuel...easy to do, there's a drain screw on the bottom of each of them. Open them up, let what's in the bowls drain out, (make sure your petcock is NOT set to "PRI") and try starting the bike....fuel should start running out of each drain.
post #7 of 9 (permalink) Old 05-27-2016, 10:58 AM Thread Starter
Thanks for the suggestions hopefully one of them will get me back on the road without costing me my shirt.
post #8 of 9 (permalink) Old 05-28-2016, 01:17 AM
Results - Synopsis needed .... !
pls respond ....... - -
Thorn likes this.
post #9 of 9 (permalink) Old 05-29-2016, 09:37 PM Thread Starter
Is it possible an electrical issue caused this problem?
