surface prep tips for gaskets - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 05-06-2016, 10:44 AM Thread Starter
Got any tips on ensuring clean, undamaged surfaces for gasket install (especially split cases)? tips and no-no's, success and horror stories welcome
Its soooo easy to damage aluminum with a razor blade as I've discovered.
What do you use? Scotch brite pads? plastic scrapers? those nubby plastic grinding pads car guys use?
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #2 of 11 (permalink) Old 05-06-2016, 10:51 AM
calebj's Avatar
I used a razor blade carefully for cleaning up the block mating surfaces, then ordered a gasket scraper and some gasket removing spray. Haven't tried those yet. The razor blade worked well enough if you're cautious, but it takes a lot of time to do it well. When I was done with the blade, I wiped everything down and ran over it with aluminum polish.
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #3 of 11 (permalink) Old 05-06-2016, 10:55 AM Thread Starter
theres no substitute for patience in many things it seems
2002 vn750
40/138 jetting
gidaeon is offline
post #4 of 11 (permalink) Old 05-06-2016, 11:46 AM
Tinkerer
Gaz73's Avatar
I use Three Bond gasket remover and a plastic scraper
Man can not live by bread alone... he needs Duct tape & WD40
Gaz73 is offline
post #5 of 11 (permalink) Old 05-06-2016, 11:54 AM
Expendable newbie
evulcannibal's Avatar
In the past, I've used Popsicle sticks in place of a plastic scraper. I just cut or sharpen the end of the stick so that it is like a knife's edge. I didn't cut the side of the stick, only one end of the stick. Then I scrap away. When it gets too dull, I just resharpen it.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #6 of 11 (permalink) Old 05-06-2016, 12:24 PM Thread Starter
bonus points to you for creativity, thriftiness, ..and the best screen name on the site.
2002 vn750
40/138 jetting
gidaeon is offline
post #7 of 11 (permalink) Old 05-06-2016, 02:06 PM
Expendable newbie
Finally, somebody mentions my screen name. I worked very hard on that. My favorite part is that it contains the word vulcan.
95 VN750
Blacked out engine
Gear indicator
post #8 of 11 (permalink) Old 05-06-2016, 02:41 PM
Such a slick name and such a fancy profile pic, I just assumed you were a long-time member!
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #9 of 11 (permalink) Old 05-06-2016, 03:23 PM
Expendable newbie
Shoot, I wish I was a long time member. That would've mean that I had my bike for way longer. I should've started riding a long time ago.
95 VN750
Blacked out engine
Gear indicator
post #10 of 11 (permalink) Old 05-06-2016, 04:35 PM
I'm a rider
One1's Avatar
sandpaper wrapped around glass gives the flattest surface, but some things have nubs sticking out so you cant lie them flat on the glass.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is online now
