Disk brakes? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 08-28-2008, 02:32 PM Thread Starter
Disk brakes?
I recently had some insurance work done after being t-boned. One of my disk brakes on the front took some damage but the other front disk was fine. They only replaced the one disk and now I can pull the handle all they way and it won't lock the tire. Is that from having two different disks with different amounts of wear?
Rungaul is offline
post #2 of 14 (permalink) Old 08-28-2008, 02:53 PM
Calif Rider
weh44att's Avatar
Two different disks should not make much of a difference. Sounds more like the cable is not adjusted correctly, or there is air in the system. This would give you weak pressure on the disk. The calipers should adjust to each disk and give you good breaking power. The air gives you sponge breaks like what happens on cars with air in the system. Does the brake lever get hard to pull, the more you pull, or does it go right to the handle. If it goes to the handle I would say you have air in the system. The other thing is did they get some grease on the disks, this would keep the bike from stopping also.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 14 (permalink) Old 08-28-2008, 02:54 PM
hbhobby's Avatar
I would try bleeding the brakes, both of them. Sounds like you might have air in the lines.
Can you tell if the caliper is squeezing when you pull the lever?
hbhobby is offline
post #4 of 14 (permalink) Old 08-28-2008, 04:09 PM
Who is "they" ?? , as in "they" only replaced the one disc. (there is no K)
Guessing you mean a dealer's service department?
How many miles have you gone on the new brake?
New brakes take time to "bed in" ..but sounds like they just did a lousy job of bleeding the brakes...so I'd take it back and make them do it right.
post #5 of 14 (permalink) Old 08-28-2008, 04:35 PM Thread Starter
I've gone about 20 KM on it. When I pull the lever till it bottoms out on the throttle the calipers only move the smallest of distances, it's almost not noticeable. The did only replace the one disc. If I repeatedly pump the lever the feeling doesn't change.
Rungaul is offline
post #6 of 14 (permalink) Old 08-28-2008, 04:56 PM
Take it back to whoever did the work and make them fix it. Again, sounds like they did a lousy job and it should all still be covered by insureance...
post #7 of 14 (permalink) Old 08-28-2008, 05:28 PM
750Doug's Avatar
Ditto.
Sounds like low fluid/air in the lines. "They" aren't done working on it yet....
750Doug is offline
post #8 of 14 (permalink) Old 08-28-2008, 05:38 PM
Is the HORN any louder???
post #9 of 14 (permalink) Old 08-28-2008, 05:40 PM
750Doug's Avatar
Rotf!!
750Doug is offline
post #10 of 14 (permalink) Old 08-28-2008, 06:58 PM
Sky Rider's Avatar
One more reason I do my own work.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
