Rain issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Thorn
post #1 of 8 (permalink) Old 05-02-2016, 12:57 AM Thread Starter
Jb87's Avatar
Rain issues
My bike seems to stumble a bit when it's running in the rain, the headlight will cut out for a second, the engine stumbles, then she picks back up. Does anyone else have issues like this? Is it a common problem with the Vulcans?
New rider, first ride -85 vn700- 2 wire mod
Jb87 is offline
post #2 of 8 (permalink) Old 05-02-2016, 06:51 AM
Hooray for Pittsburgh weather, eh? Rode in mild rain this week and experienced no ill effects.
Seems weird that both the headlight and engine are effected. Water getting into an already-loose connection? Seems like the open would have to be shared by both the battery and the regulator voltage output (since both would have to fail together in order to lose power while riding). The battery compartment should be pretty well protected from water ... possibly water getting into the ignition switch?
Jb87 likes this.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #3 of 8 (permalink) Old 05-02-2016, 07:15 AM Thread Starter
Jb87's Avatar
It's a good place to start at least,I will try covering it next time. I should also mention it happened after riding about 25 minutes in a light rain. And only a couple times. But definitely only in rain.
Jb87 is offline
post #4 of 8 (permalink) Old 05-02-2016, 10:39 AM
If it wasn't for this statement, I first suspect the ignition switch and/or its connector.
Do you ride with a heavy set of keys hanging out of the ignition switch ?
Some past members discourage this......
hope this helps - -
post #5 of 8 (permalink) Old 05-02-2016, 10:57 AM
Stator wires getting wet? Ign. switch wet?
My signal flasher got wet and signals went nuts. Had to dry it out and seal it up.
edit: flasher was also hanging upside down
post #6 of 8 (permalink) Old 05-02-2016, 11:19 AM
I'd go through and clean all connectors with electronics cleaner and pack them with dielectric grease to protect them from the elements.
post #7 of 8 (permalink) Old 05-02-2016, 11:45 AM
X2 definitely the ignition switch.
post #8 of 8 (permalink) Old 05-03-2016, 12:07 AM Thread Starter
Jb87's Avatar
No, no heavy keys. It's on its own ring with just a plastic tag. Will go thru the connections. That's another good suggestion thank you!
Jb87 is offline
