Stalling issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-22-2008, 11:19 AM Thread Starter
Stalling issue
I ran out of gas this morning and killed the factory battery trying to start the bike from the reserve tank. I was able to get the bike jump started after getting some gas in the tank. Now when I ride the bike it runs fine for a bit on the interstate but then acts like it is going to stall so I down shift then drive for a bit in first/second gear then things start running normal again. It feels like the bike isnt getting any gas - could this be a battery issue. I tried to find a MF battery locally here but havent had much luck for under $100.
dobgolf is offline
post #2 of 4 (permalink) Old 08-22-2008, 12:40 PM
Glenn M's Avatar
Where is around here?
Sears, Advance Auto, Wal-mart, Sam's club most are around $70.
Also check your gas cap vent.
Glenn
1985 VN700
Saddle Bags
Small Sport Windshield
R/R moved
Home built coasters
Kaw touring front fender
1990 Fuel tank
Kenda Kruz 110/90-19 & 170/80-15 tires
NGK Iridium plugs
NGK plug caps and 7mm copper core wires.
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #3 of 4 (permalink) Old 08-22-2008, 03:22 PM
ChrisC's Avatar
You also might have gotten some junk stuck in the carbs from the bottom of your tank. I'd try a healthy dose of Seafoam, then depending on how that goes check the screen in the petcock. In any event the MF battery is a good idea regardless.
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #4 of 4 (permalink) Old 08-22-2008, 05:43 PM
San Diego Vulcan Rider
DeForestSD's Avatar
Hate to say it but you might want to check if your stator is charging the battery. It happened to me. Battery died, push started but ran rough. Sure enough, it was the stator. Replaced it, the R/R and the battery. Been running great for 5k miles.
86' Vulcan, Stock & Lovin it!
Stator, R/R, splines lubed, ACCT's repl. at 25,200
Just turned 29,000 mi.
95' Vulcan, all stock, 9,700 mi.
John Spangler
DeForestSD is offline
