gas mileage issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 04-15-2016, 02:19 AM Thread Starter
I'm a rider
One1's Avatar
gas mileage issue
My bike gets 130 miles per tank usually. The last 2 times I filled it up it got 68 miles each time. Something has changed dramatically. Give me some ideas what to check. I looked for leaks, but found none. I know it dries fast so I looked very well. Since I have eliminated leaking as the issue I need to look towards places it could be burned, trapped and evaporating, etc.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #2 of 3 (permalink) Old 04-15-2016, 02:30 AM
Check: Petcock vacuum line (both ends), it should be dry. Oil level (ahem), and does it smell like gas?
Meanwhile, read this if you haven't already: https://www.vn750.com/forum/22-carbs-...en-parked.html
Having this same problem with mine right now. My oil is over full and smells like gas, vac line is wet at the carb. It's a dang pandemic!
post #3 of 3 (permalink) Old 04-15-2016, 03:20 AM
RoadHopper's Avatar
First thing that *I* would check would be that i was checking the right bike, but i'm probably older than you and did a lot of drugs when i was young.
Thank gawd i only have one bike now.
Do you both have the new petcock with the OFF and no Prime?
RoadHopper is offline
