riding then nothing!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 08-12-2008, 07:25 PM Thread Starter
i dont get this damn thing ill be riding on the freeway doing good then all of a sudden it will start sputtering and wont accelerate with you give it gas so i pull off, open the tank shake the gas around and sit for a few then i turn the key it fires back up and runs fine i get home and open the gas cap pour some seafoam and let it run for 20 minutes and i notice when i give it throttle theres some type of smoke coming out the pipes buts its not blue so i adjust the carbs about 2.5 turns maybe alittle more. i dont get it this is the second time its happen where ill be on the free way and bam just cuts out. i wonder if the carbs should come out and be rebuilt or something. grrrrrrrrr
great 1 is offline
post #2 of 8 (permalink) Old 08-12-2008, 08:11 PM
HAWK
Ccspinner's Avatar
There is a comon probem where the vent tube gets plugged causing vaperlock.
Check your gas cap and the little tube running out of the back of the gas tank and down to the ground.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 8 (permalink) Old 08-12-2008, 09:44 PM
Love My Baby
rubyrick's Avatar
Sounds like the phantom out-of-gas syndrome, to me. Lots of discussion about that on this forum.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #4 of 8 (permalink) Old 08-12-2008, 10:06 PM
Again it won't hurt, if you haven't, to replace the vac hose to the petcock.
post #5 of 8 (permalink) Old 08-12-2008, 10:19 PM Thread Starter
im gonna try all of those but its just wierd i just had it out for the last hour and i filled up to make sure i had lots of fuel and so far no problems . also a quick question i did the marble thing and do you have to block the part where the carb vent tube went to i blocked off the card hose but the one on the pollution thing is still open???
great 1 is offline
post #6 of 8 (permalink) Old 08-12-2008, 10:25 PM
Crobins365's Avatar
If you marble, you have to block off pretty near everything - both hoses to the reed valves (part of the emissions system), the vacuum line coming off the rear cylinder. You definitely don't want to block off the carb vent tube (goes to the right ear) - still needs to vent out of there.
C
Crobins365 is offline
post #7 of 8 (permalink) Old 08-12-2008, 10:25 PM
[QUOTE=great 1;67018]im gonna try all of those but its just wierd i just had it out for the last hour and i filled up to make sure i had lots of fuel and so far no problems . also a quick question i did the marble thing and do you have to block the part where the carb vent tube went to i blocked off the card hose but the one on the pollution thing is still open???[/QUOTE]
Yes, plug it. I used a bottle cap silacone and a small clamp.
post #8 of 8 (permalink) Old 08-12-2008, 10:49 PM Thread Starter
yeah i marbled both sides and i blocked off the one that went from the carb to the pollution thing and left the little part on the pollution thing open . so i will block it off tomorrow with a hose and a screw or something of the nature. i wonder if its possible that the petcock hose is collapsing under pressure causing it to not get any fuel. hmmm. thanks for the help guys
david
great 1 is offline
