running lean - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 08-08-2008, 11:11 PM Thread Starter
running lean
took the vulcan to a mech yesterday and he told me today that 2 of the cylinders are running lean and he has to find out where its sucking air from.Anyone ever experience this and have any suggestions?Thanks in advance
dman is offline
post #2 of 10 (permalink) Old 08-09-2008, 04:01 AM
750Doug's Avatar
That depends; which two cylinders are lean, does he know? And there are a couple places they could be sucking air...
750Doug is offline
post #3 of 10 (permalink) Old 08-09-2008, 07:43 AM
That is a tough question... Should be some tests he could run to determine which 2 cylinders...... The devil makes me say things sometimes......lol...
BTW-Welcome dman...
post #4 of 10 (permalink) Old 08-09-2008, 08:25 AM
750Doug's Avatar
Me too Dog, me too...and yes, welcome Dman.
750Doug is offline
post #5 of 10 (permalink) Old 08-09-2008, 10:39 AM
About the only two places that the two only cylinders would be sucking air that is unwanted, is at the clamps that are between the carbs and the engine. Unless the rubber boot is ruptured, or a vaccuum line is off. Such as the one to the reed valve control (rear carb) or the petcock control (front carb).
Welcome, dman, I almost miss spelled it.
post #6 of 10 (permalink) Old 08-09-2008, 02:36 PM Thread Starter
found it
2 of the jets in the rear carbs were clogged.Mech told me he had to loosen and tilt the engine to get at the carbs.Wow alot different than what i was used to Thanks guys
dman is offline
post #7 of 10 (permalink) Old 08-09-2008, 03:55 PM
Welcome Dman,
Just to make it clear, Vulcans only have 2 cylinders, and two carbs. One front one back. And I can't think of a reason the engine would have to be tilted to pull the carbs. I think your tech was taking you for a ride. How many hours did he charge you?
85 VN750 basketcase ( yes its a true 750, and no smog controls, its good to be Canadian)
It will have
a rebuilt 96 top end, rebuilt 85 bottom end
degoated, Eared
stripped, lowered, raked, bobbed,
reed valve boxes shaved
ported and polished
balanced
right side dump exhaust
heads and cylinders shaved for compression
looking for smoothbore sidedraft carbs
possibly fat bob tanks
modified vn800 or sportster drag pipes or I'll just make some
Chopperfix
Duck's Garage
Duck is offline
post #8 of 10 (permalink) Old 08-09-2008, 10:19 PM
fergy's Avatar
Ouch! Dman, I would be leery of using this mechanic. Maybe he saw 4 plugs and got confused, but most decent mechanics would know a v-twin by the sound if not by the sight... Plus, you don't have to tilt the engine to get at the carbs. Weird!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #9 of 10 (permalink) Old 08-09-2008, 10:24 PM
Sky Rider's Avatar
An engine tilt is 9/10 of an engine pull. Not a short procedure. It takes about a day to do and that doesn't count reinstall. I hope he meant something else but I have my doubts since he didn't even know how many cylinders the thing has. Our bikes do have 4 spark plugs, two per cylinder. The uninformed may assume 4 cylinders from that but an experienced mech should not. The Honda Shadow is the same way, 4 plugs, 2 cylinders.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #10 of 10 (permalink) Old 08-10-2008, 07:58 AM Thread Starter
explain
I think I explained what he said a little distorted guys.I am an air cond mech just getting back into the bike world after 25 years away.He fixed it for a fair price and showed me digital pics of his work in stages.Thanks for the responses and enjoy your ride today.Sunny high of 80 degrees and 40 % humidity cant wait to ride!
dman is offline
