Part out, junk, or fix? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 12 (permalink) Old 01-06-2016, 01:16 PM Thread Starter
93VN750's Avatar
Question Part out, junk, or fix?
Not sure what to do with my bike. It has 24k miles on it. Recently tore apart engine to replace head gasket and every other plastic or rubber part inside.
Had it running for a little bit, but have had constant problem with mechanical seal. Originally leaked AF, took it apart and replaced impeller (one side of seal) and the mechanical seal. Did not initially leak anything, then started leaking coolant, then added oil, now it smells as though gas is also coming out.
If I knew the issue, and it was reparable, I would do it. But it seems like there is no one good answer, so I consider parting it out, or junking/scrapping it.
All thoughts, suggestions, and ideas are welcome.
I was away from this board for a few years while I had my Meanie. Back in the day, there seemed to be a higher degree of technical help here than now.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 12 (permalink) Old 01-06-2016, 06:09 PM
Could the pump itself be bad?
post #3 of 12 (permalink) Old 01-06-2016, 06:49 PM
On goldwings the impeller shafts wear out and they leak around it
post #4 of 12 (permalink) Old 01-06-2016, 07:13 PM
2000 VN 750 Senior Member
Originally Posted by 93VN750 View Post
......I was away from this board for a few years while I had my Meanie. Back in the day, there seemed to be a higher degree of technical help here than now.
Jon
Not quite sure of your intended meaning with the above statement but I do remember you being more active at one point and then you were quiet for a time. Maybe some of the other active technical minded members have done the same as you or it could be that the vast majority of needed answers can be found using the search option available. There is a vast number of great videos and full write ups with pictures to tear most any portion or complete VN750 contained here without long drawn out technical answers. I also do not read too many if any posts asking for further or deeper answers once several opinions are given as to a remedy. Maybe I am misreading your comments. Believe me, I am not trying to say you are wrong but rather unsure what exactly you mean by your words. If there is something lacking I hope wiith your renewed attention here it can be improved. Welcome back.
DACataldo likes this.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #5 of 12 (permalink) Old 01-06-2016, 07:26 PM
Since I've not had to deal with this problem, I can't help a lot, other than to say ...
I recall someone in the past couple of years that posted about a new mech. seal continuing to leak. Seems like there was some little trick or fix the poster did that finally got the leak stopped.
I know the search here can be a pain to use, but I've dug up some good info using it. Just have to deal with wading through the results.
post #6 of 12 (permalink) Old 01-07-2016, 09:18 AM Thread Starter
93VN750's Avatar
It just seemed like if you had a question or problem, there were more/faster responses available than now. Please factor in a degree of frustration I am going through which always will cloud ones thinking.
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #7 of 12 (permalink) Old 01-07-2016, 09:20 AM Thread Starter
93VN750's Avatar
That is a possibility considering the amount of crud that I encountered inside the impeller shaft tunnel. Wish I had thought of that while the engine was out as replacing it then would've been a snap. Now it's a pull and split deal.
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #8 of 12 (permalink) Old 01-07-2016, 09:22 AM Thread Starter
93VN750's Avatar
I searched every combination of mechanical seal, water pump leak, etc. that I could think of and did not see the light. It is out there, just have to figure out how to find it.
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #9 of 12 (permalink) Old 01-07-2016, 09:56 AM
The site isn't visited like it used to be
post #10 of 12 (permalink) Old 01-07-2016, 10:57 AM
Just went 10 pages deep in one search, didn't find what I was looking for.
This forum has had years worth of posts disappear at random recently.
About the only item I saw was talking about using the proper sized tool to drive the seal in, otherwise it could distort the metal or no seat it properly. Still not the post I had in mind.
