94 750 problems - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 12-14-2015, 06:20 PM Thread Starter
94 750 problems
I got a 94 750 started ran fine cold but would only run choked wouldnt start when hot and cutut while running cleaned the carb reset the adjustments repalced ignition coils plugs wires ect got it to run off choke but stilk would cut off when it got hot and would not start i started tearing it down to replace the stator and found the pickup coils and stator looked fairly new one of the pickup coils had exposed wires im assuming this was causing a short with i think would explain my issues im going to clean it up reseal the wires test to make sure pickup coils and stator are still good....... im new to this so any advice would be great could this be causing my problems anything elses i should look in to for my problem ?
Brockes is offline
