Questions from a new owner of a VN750... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 07-27-2008, 10:52 PM Thread Starter
robardin's Avatar
I just got my first motorcycle, a 1994 VN750.
It didn't come with a manual. Can I still get one? Or do "The Vulcan Verses" here serve as a superset of information? I suppose I'll get either the Clymer's or Hayne's book; any reco's on which is better or how they are different?
Also, it came with three keys. The previous owner could not specify what the third key was for. One is for the ignition, fuel cap, and helmet locks. The other is for the compartment behind the rear seat. And the third key is the same make, fits both locks and is stamped "Kawasaki", but does none of those things. Wuzzit4?
robardin is offline
post #2 of 22 (permalink) Old 07-27-2008, 11:02 PM
750Doug's Avatar
Probably a previous bike, or an old one for your bike that has since been re-keyed. He might have just added it to the key ring during the sale, as he had it laying around and thought it belonged to the Vulcan. There are no other locks on the bike.
750Doug is offline
post #3 of 22 (permalink) Old 07-27-2008, 11:08 PM Thread Starter
robardin's Avatar
OK, that makes sense.
robardin is offline
post #4 of 22 (permalink) Old 07-27-2008, 11:30 PM
Some go with both, they are cheap books, and they cover th same things a bit differently, wirh different illustrations. It always good to have a different angle on things
85 VN750 basketcase ( yes its a true 750, and no smog controls, its good to be Canadian)
It will have
a rebuilt 96 top end, rebuilt 85 bottom end
degoated, Eared
stripped, lowered, raked, bobbed,
reed valve boxes shaved
ported and polished
balanced
right side dump exhaust
heads and cylinders shaved for compression
looking for smoothbore sidedraft carbs
possibly fat bob tanks
modified vn800 or sportster drag pipes or I'll just make some
Chopperfix
Duck's Garage
Duck is offline
post #5 of 22 (permalink) Old 07-27-2008, 11:35 PM
Love My Baby
rubyrick's Avatar
When I bought my bike new, it came with two keys. One for the chain lock that came with the bike (stored in the toolbox compartment behind the seat), and one for everything else. That second key worked the toolbox lock AND the ignition, etc.
Seems like the PO re-keyed the rear compartment, or likely the lock fell off and got lost. Our bikes have a rep for that happening. The Vulcan Verses recommend using silicone to secure the lock.
If you don't have the chain & lock in the toolbox, that's probably what the 3rd key was for.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #6 of 22 (permalink) Old 07-28-2008, 12:29 AM
I personaly have 4 manuals. I have the Clymers, The Haines, The Download manual, and the Kaw Disc. Wich one do i use the most??? all of them the same amount.
post #7 of 22 (permalink) Old 07-28-2008, 09:42 AM Thread Starter
robardin's Avatar
What are these last two? Assuming "the download manual" is downloadable, where from?
robardin is offline
post #8 of 22 (permalink) Old 07-28-2008, 10:03 AM
HERE is the download manual...it takes quite a while to download...but well worth the time.
HERE is the Kawasaki Factory Repair Manual...from Ebay...Not sure if it si the same one I have or not...but still worth the look.
post #9 of 22 (permalink) Old 07-28-2008, 10:51 AM Thread Starter
robardin's Avatar
Holy moly. 2,395 pages?? I guess I won't be printing this sucker out!
robardin is offline
post #10 of 22 (permalink) Old 07-28-2008, 10:58 AM
That downloadable manual includes a complete parts list, as well as the shop manual.
Best bet is to burn it to a disk, then print out pages as you need them.
