Engine stops running when it is warm/ hot. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 11-10-2015, 08:47 AM Thread Starter
Unhappy Engine stops running when it is warm/ hot.
Hello,
I am a Dutch guy who bought my Vulcan 750 in may this year (+/- 17.000 Mile)
The problem with my Vulcan 750 1992 is as follows.
It is starting quite quickly (new battery), but after driving a lot of miles (when the engine is warm/ hot) it is starting to run on only 1 cylinder and not much later it stops completely.
After cooling down a while it is running again, but after a few miles the problem is back.
What can this be and how to solve this problem?
Kawad is offline
post #2 of 9 (permalink) Old 11-10-2015, 10:59 AM
Are you sure it's not Poogs (Phantom out of gas syndrome) When it happens is the tank around half full? Next time it starts to run funny, pull over and pop the gas cap and then put it back. Does the bike now run better?
post #3 of 9 (permalink) Old 11-18-2015, 09:38 AM Thread Starter
No, I have tried your solution several times, but is does not work...
So far I tried a "new" bobine and ignition-unit to, but the problem still remaines...
Kawad is offline
post #4 of 9 (permalink) Old 11-18-2015, 11:15 AM
Question
Not familiar with 'bobine' or which ignition unit you replaced, can you describe?
Check to see if the bike is charging when hot. Does the starter turn normally when the engine has stalled?
post #5 of 9 (permalink) Old 11-18-2015, 11:20 AM
Could also check the petcock when it has stalled, might be losing fuel flow there, but not due to POOGS..
post #6 of 9 (permalink) Old 11-18-2015, 02:26 PM
Is it running hot?do you smell gas?
post #7 of 9 (permalink) Old 11-18-2015, 07:42 PM
If it starts good, and runs good for awhile, that eliminates quite a few things. The only things left are gas and ignition. Either the ignition is cutting out, or something is stopping the flow of gas. My Vulcan 750 (both of them actually, I've had 2, a '93, and now an '02) have always had the habit of sometimes starting up on one cylinder, then several seconds the other cylinder kicks in. It doesn't do that all the time, but often enough to notice. Even after I completely overhauled the carbs it still does it. I never found the cause. The '93 had an issue right after I bought it new where the rear cylinder would flood out. It was under warranty, but I did not trust the dealer to work on it after an incident with another bike, so I did it myself. I found the float in the rear carb had a piece of flashing sticking out where the seam was molded together, and it would occasionally catch on the carb body. I trimmed it down, and it ran fine.
You said it starts running on one cylinder, then the other one cuts out later. That means something that can affect one cylinder at the time. Possibly the carbs or pickup coils? It may be difficult to find, since it happens intermittently. By the time you can check it, the problem may have disappeared. Even though the petcock feeds both carbs, I would make sure you are getting a good flow of fuel from that. If you are not in the U.S., I'm assuming you don't have to deal with alcohol laced gas. Has the bike had this problem ever since you bought it? Has it gotten any better or worse? Have you noticed anything else odd? How long do you have to ride it before this issue happens?
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #8 of 9 (permalink) Old 11-18-2015, 10:18 PM
Could possibly be a sticky float needle in the rear carb?mine had an issue similar and would flood out the rear cylinder and would run on one cylinder then cut out
post #9 of 9 (permalink) Old 11-23-2015, 09:39 PM
I had this problem plague my bike for over a year, turned out to be a simple kinked/frayed wire. Trace ALL your wires coming from the stator to their endpoints. I suffered with it for so long because i skipped this step.
May not be the solution for you but will save you loads of cash and headache if it is.
2006 Vulcan 750
Ear Shaved
Re-jetted
ACCT --> MCCT Conversion
TW200 Petcock
www.michaelcmichaeldo.com
mcharles13 is offline
