Some thing cool - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By mrseedsower
post #1 of 8 (permalink) Old 10-20-2015, 04:49 PM Thread Starter
Smile Some thing cool
My cap on my vacuum on the front cylinder where I did the Tw200 petcock came off somewhere down the line. This past week I figured that out. It stopped the ticking I thought was in the cam tensioner.
I had an idea about the cap as it was only a bolt shoved into a hose to cap it off. I got a dowel almost the same size as the tube and made the tube long enough that I could put a piece of dowel down in the tube and then seal it with hot glue. Worked like a champ. The ticking is gone and now my bike is running a whole lot better.
new rider 9984 likes this.
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 8 (permalink) Old 10-20-2015, 10:40 PM
awesome bro
post #3 of 8 (permalink) Old 11-14-2015, 12:35 AM
I used a car vacuum cap to cap off the fitting on the rear carb, left when I removed all the emissions crap. But it rotted in a fairly short time. I replaced it with a vacuum hose with a screw in the end, and stuck it up under the tank. I have no idea why the cap rotted and the hose doesn't. So what is it with the TW200 petcock? The TW200 is a single cylinder engine. Do you just put a T inline to connect it to the Vulcan carbs? Is it a direct fit on the Vulcan tank? If it is not too difficult, I might go that route when my vacuum petcock starts leaking again.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #4 of 8 (permalink) Old 11-14-2015, 09:43 AM
Mcneuby's Avatar
The TW200
It is a direct fit to the tank. and use a T fitting to split the line. It is a piece of cake. If you do it buy a Yahama part not the cheapest one you can find. I bought one at the Yahama shop and it was still under $25.00.
New to me 2004 15k Last liscened in 2011. Stock as they come.
Mcneuby is offline
post #5 of 8 (permalink) Old 11-14-2015, 02:17 PM
Very common Vulcan mod
OleDirtyDoc is online now
post #6 of 8 (permalink) Old 11-14-2015, 03:21 PM
just remember if you do it, to spend the extra few bucks, and get the genuine article.. many of the cheap china knockoffs are worse than nothing
post #7 of 8 (permalink) Old 11-14-2015, 06:32 PM
calebj's Avatar
Agreed. When I checked a month ago, the genuine oem unit could be sourced online for less than $20 from reputable dealers. No reason to risk a knock off.
calebj is offline
post #8 of 8 (permalink) Old 11-16-2015, 09:29 AM
As far as fuel flow through a single cylinder petcock, take a 1/4 piece of tubing and funnel and pour water through it and see how much flows. You should get plenty of fuel.
