Glove Box - Bad hinge - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 07-18-2008, 02:08 PM Thread Starter
Is it just me or is the design of the glove box hinge bad.
95% of the hinge is already broken and looking for a way to fix it. Has anyone else had this problem and if so, how did you fix it?
jtdev is offline
post #2 of 10 (permalink) Old 07-18-2008, 02:16 PM
im suprised no one here has fabricated a steel one yet. i bet a chrome or ss one would look real good and be near indestructable.
dutter is offline
post #3 of 10 (permalink) Old 07-18-2008, 02:29 PM
Naw.... no one here has had that problem.............lol
I just mentioned that to a perspective Vulcaneer, that it's one thing he should be aware of.
There have been more than a few here who've made something to work better than stock.
A hinge, a couple nuts & bolts and you're better than new!!
HERE is a link to the Vulcan Verses that talks about the hinge.
And don't forget about the nut that holds the lock on. Many here have lost the lock when the nut worked itself loose, and the lock went bye-bye....somewhere down the road.
A few dabs of silicone adhesive on it (as well as the chrome plastic swing arm caps) and you shouldn't have to worry about them leaving your bike any time soon.
post #4 of 10 (permalink) Old 07-18-2008, 02:59 PM
Sky Rider's Avatar
One the the PO's on my bike drilled 4 small holes and used cable ties to make a hinge. The ties are black so they don't show and it's worked great for the last 5 years.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #5 of 10 (permalink) Old 07-18-2008, 10:49 PM
Glenn M's Avatar
Go to the hardware and get you some Gorilla brand tape. Just put a piece across the inside of the box over the hinge, it will work just fine and the door won't fall off. Plus put some RTV on the the nut of the lock, they do vibrate loose and the lock falls out. Trust me I know.
Glenn
1985 VN700
Saddle Bags
Small Sport Windshield
R/R moved
Home built coasters
Kaw touring front fender
1990 Fuel tank
Kenda Kruz 110/90-19 & 170/80-15 tires
NGK Iridium plugs
NGK plug caps and 7mm copper core wires.
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #6 of 10 (permalink) Old 07-19-2008, 10:20 AM Thread Starter
Well I fixed it and it only cost $2.00.
I used one side of a strip of velcro (the hook side) and cut it to fit as the hinge from the inside. This stuff works perfectly. First of all, no holes. Then it's black (matches great) and weather proof, flexible, and wears like iron. You can't pull that stuff apart once stuck to the plastic.
I was looking in Home Depot for a hinge, and couldn't find anything I liked and just happened past the velcro display and started thinking..
This is the simplest solution and looks like factory.
jtdev is offline
post #7 of 10 (permalink) Old 07-19-2008, 10:53 AM
Glenn M's Avatar
Sounds like a good fix to me.
Glenn
1985 VN700
Saddle Bags
R/R moved
Home built coasters
1990 Fuel tank
NGK Iridium plugs
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #8 of 10 (permalink) Old 07-19-2008, 01:58 PM
I used a small door hinge mounted on the inside held in place with rivets. All that you can see are the rivet heads.
jworth is offline
post #9 of 10 (permalink) Old 07-21-2008, 02:12 AM
This is what I did. https://www.vn750.com/forum/showthread.php?t=4902
2001 VN750
Vista Cruise Control
V-Force shield
Kawasaki Saddlebag supports
Fixed trunk hinge
TOC MCCT
Clear Alternatives LED tail light
Knifemaker style floorboards
Knifemaker style dash
Avon Venom X 110/90 Front
Avon Venom X 170/80 Rear
Big Crank AGM battery
25,100 miles as of 04/20/2010
lancer19 is offline
post #10 of 10 (permalink) Old 07-21-2008, 08:12 AM
Glenn M's Avatar
Here's another option, especially if you've already lost the door. Similar to Hyper's setup. BAG
Glenn
1985 VN700
Saddle Bags
R/R moved
Home built coasters
1990 Fuel tank
NGK Iridium plugs
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
