Need help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 09-17-2015, 02:23 PM Thread Starter
Need help
So literally I just purchased my 2001 Vulcan 750 yesterday and I need to change the oil and spark plugs, and of course the bike came without a manual of any kind so...
What type of oil should I use? I am in a colder climate here in eastern Idaho if that makes a difference.
How much oil will my bike need?
And what kind of spark plugs do I need to get?
Sorry I know stupid questions, but I figured you guys would know... I can't seem to find a specific answer online anywhere.
Connorcc10 is offline
post #2 of 14 (permalink) Old 09-17-2015, 02:27 PM
The bike uses standard 10w-40. You can also use Rotella 15w-40 as well, many people (including me) swear by it.
Do not use any 'high mileage' oil with added stuff. Base 10w-40 dino oil, or if you want to send $50 on an oil change you can go with the synth motorcycle oils (Mobile 1 RT, etc - not really suggested for our lower performance engine)- 3.25-3.5qts to fill her up - watch the sight glass and take your time (center stand).
Spark plugs are in my signature - go for the iridiums like I have. Makes a world of difference.
Look into replacing the battery with an AGM style if it has a standard wet cell.
post #3 of 14 (permalink) Old 09-17-2015, 02:35 PM Thread Starter
What do you mean spark plugs are in your signature? Is there a specific number for which ones I should get?
post #4 of 14 (permalink) Old 09-17-2015, 02:36 PM Thread Starter
By the way thank you for the info VERY helpful!
post #5 of 14 (permalink) Old 09-17-2015, 02:40 PM
Yes, read my signature below the post. It lists the spark plugs.
post #6 of 14 (permalink) Old 09-17-2015, 06:33 PM Thread Starter
Do you guys know what this fluid is? Right side of the bike ???
post #7 of 14 (permalink) Old 09-17-2015, 07:21 PM
engine coolant over flow tank. antifreeze/water mix in there
post #8 of 14 (permalink) Old 09-17-2015, 09:15 PM
Whatever you do DO NOT drink from it.you will lose a slipper and your bike will turn into a pumpkin at midnight.you will get home,the house will be on it's side,Toto will be pregnant,Dorothy will be banging the gay neighbor,and Chris Tucker will be running around in a pink thong screaming" no one understands the words coming outta yo moufh"
post #9 of 14 (permalink) Old 09-18-2015, 10:17 AM Thread Starter
Thanks for the info guys one last thing for now at least, when I went to check the brake fluid in the front brakes it looked like old used oil, so I bled the whole thing and put new fluid and tried for hours to get the air out and get the pressure back but no luck? Is there a special way to do it? I currently have no front bakes :/
post #10 of 14 (permalink) Old 09-18-2015, 07:53 PM
You might find some help here: https://www.vn750.com/forum/27-wheels...ont-brake.html
