oil light came on....
I rode in to work and back, no troubles. This morning i poured in a bottle of Seafoam in the gas tank and when I got home, I was pulling the bike backwards to its parking position on the walkway, the engine was still running and then the oil light came on. I turned it off for a minute or so, turned the key to the on position and the neutral and oil light was on. I went ahead and started it up and the oil light immediately went out.
Can the oil light come on like that giving a "false reading" so to speak?
Sponsored Links | |||
THat sounds a little odd, although I s'pose there could be a problem with the sensor. Your oil level is otherwise ok? And you didn't drop the bike or anything (see this thread: https://www.vn750.com/forum/showthread.php?t=7193)? You might just check the sensor connection and make sure it's on snugly (maybe as you were backing up you hit the lead with your leg or something??).
Did you pour a whole bottel of sea Foam in the tank?
If so that is way to much, not sure what it will do but you will probabley be running lean. Even a full tank is only 3 gallons, I believe 3 oz per 8 gal if I rember right.
I do not see any way sea foam in the tank will affect the oil light though.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Other than the above, what oil filter are you using...???
Just wondering as I think I had a prob. with Fram filters on my 03 bike...
Have a good one Old Dog...
Southern Central Tennessee....
Now on the Dark Side...
Girl's Bike 09 Sporty xl 1200 Custom...33k + & clickin...
Originally Posted by Ccspinner
View Post
Several members have done it with great results. It's just IMO a better alternative to taking them out to clean.
I would check the level and also see when it was changed last. You may need to change it and the filter.
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
Was the bike pointed uphill? The oil pump pick up is is in the center forward part of the engine and if your oil level is low, it can cause the oil pump to cavitate dropping the oil pressure. Since it went off after, at least the pump re primed and is now pumping. Check your oil level.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
