misfire at idle - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 1 Post By Gibby
  • 1 Post By ubertalldude
post #1 of 10 (permalink) Old 08-10-2015, 11:04 PM Thread Starter
misfire at idle
The bike has been running great ever since I put it on the road. Have ridden 4k miles since June with no problems at all. Today I went to go for a sunset ride after the rain cleared up and it ran with no problems like it always does. Stopped at a store to get some smokes and when I went to leave, it started fine but when I pulled up to the road and went to take off, it started to act like it was misfiring. As I took off I gave it some throttle and it smoothed out and runs fine as long as you are into the throttle or going down the road doing about 40 and above. As soon as you start slowing down, it starts running rough and won't idle and stalls like it's misfiring. I turned the idle screw in to keep it from stalling until I made it home. I pulled the plugs and the back cylinders were fouled and wet so I cleaned them and tried to start it back up. It took a while and was backfiring. It also lit the gas on fire that was in the rear pipe so it had flames coming out of it for a bit...lol....once it started, it did the same thing, runs rough at idle like it's not firing right but when you give it some gas, it starts to clear up and smooths out. Anyone got any ideas?
showpan is offline
post #2 of 10 (permalink) Old 08-11-2015, 07:52 AM
Sounds like a dirty float needle and it is flooding.look up Wolfie's back blow mwthod
post #3 of 10 (permalink) Old 08-13-2015, 09:40 AM Thread Starter
pulled the carbs and cleaned them, bike runs great again.
showpan is offline
post #4 of 10 (permalink) Old 09-16-2017, 05:50 PM
Mine did the exact same thing this morning. However, instead of igniting the gas in the exhaust pipe, my gas was dripping onto the ground. Do you think running some sea foam in with the gas would clear it up?
Gibby is offline
post #5 of 10 (permalink) Old 09-16-2017, 07:55 PM
try Wolfie's blowback method
post #6 of 10 (permalink) Old 09-17-2017, 12:40 PM
Was going to try Wolfie's blowback method but the heads of the screws I needed to turn were worn and couldn't get the screws to turn.
Gibby is offline
post #7 of 10 (permalink) Old 09-17-2017, 06:57 PM
Thumbs up
When I first got mine it started running rough,someone recommended Seafoam. Added a few ounces and after running a half a tank of gas it rran fine and continues to do so. I add some every other tankful and also use it to store the bike.
Paulywog is offline
post #8 of 10 (permalink) Old 09-18-2017, 08:10 PM
Thanks Paulywog. I judt did exactly that. Put 2 ounces of seafoam in and sputtered on down to the gas station to fill up. Got out on the 4-lane and ran it between 75 and 80 for about 30 miles. Stopped to turn around and come back home and the idle rpm was 1100 on the dot. It had been around 500 when idling before this ride.
Paulywog likes this.
Gibby is offline
post #9 of 10 (permalink) Old 09-19-2017, 08:09 AM
ubertalldude's Avatar
2 carbs means twice the trouble! Ethanol free when you can, and/or a bit of seafoam every few tanks for maintenance does wonders for keeping these bikes running nicely.
Glad you got it worked out with an easy solution!
ubertalldude is offline
post #10 of 10 (permalink) Old 09-19-2017, 07:24 PM
Thumbs up
Glad to hear it Gibby,I use it regularly,and you can't buy gas in CT that is Ethanol free. Someone posted a pic of the inside of carbs run on Ethanol gas. Looked like cottage cheese.When I store it for winter,snow months,I put in a good dose and warm it up until I see it coming out the exhaust,then I shut the petcock and run it until it dies. Then I take out the battery so I won't be tempted to start it on a 40.degree day in January. In the spring it starts up after just a few hits on the start button. I found out about this stuff on this forum,so I'm happy to pass it on.
Paulywog is offline
