size of neck... different front end - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 38 (permalink) Old 07-06-2008, 12:55 AM Thread Starter
oglejust's Avatar
im wantin to change the front end...any1 no what diameter the stem is? and are the forks 38mm?
.... slightly modified
oglejust is offline
post #2 of 38 (permalink) Old 07-06-2008, 01:55 AM
ok had to do a little digging on this one. went to Ron Eyers to find the bearing part number and came up with 2 different bearings...one for the top and one for the bottom. come to find out the bearings are the same...just different races. PN 9116A and 9116 prospectively. they crossed over to Bearing part number HR320/28XJ which I then used to find the technical info on the bearing and came up with a inside diameter of 28mm and an outside DIA of 52MM... IMHO I wouldn't worry about our shaft size to much...but worry about what bearings will fit into our Necks...and then find a bearing that would fit both the stem and the neck...would make things much easier that way
post #3 of 38 (permalink) Old 07-06-2008, 03:09 AM Thread Starter
oglejust's Avatar
hm so ya think a 1" stem would work?
oglejust is offline
post #4 of 38 (permalink) Old 07-06-2008, 03:15 AM
well...can you find a set of bearings and seals to fit as well...that is the main question.
I am doing some reverse lookups to see what other bikes used the same bearings and seals as our bikes...and that way find a whole front end to use
post #5 of 38 (permalink) Old 07-06-2008, 08:49 AM
Fork Tube Sizes
http://www.ohiocaferacers.com/OCRTubeSizes.pdf
Neck Sizes
http://www.ohiocaferacers.com/OCRStemSizes.pdf
85 VN750 basketcase ( yes its a true 750, and no smog controls, its good to be Canadian)
It will have
a rebuilt 96 top end, rebuilt 85 bottom end
degoated, Eared
stripped, lowered, raked, bobbed,
reed valve boxes shaved
ported and polished
balanced
right side dump exhaust
heads and cylinders shaved for compression
looking for smoothbore sidedraft carbs
possibly fat bob tanks
modified vn800 or sportster drag pipes or I'll just make some
Chopperfix
Duck's Garage
Duck is offline
post #6 of 38 (permalink) Old 07-06-2008, 11:55 AM
dirtrack650's Avatar
I'm wanting to do the same. Got a GL1100 front that I'd like to attach but haven't found the time.
700/750 different sizes?
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #7 of 38 (permalink) Old 07-06-2008, 01:32 PM
The GL front end has different stem length than the VN
It will have
degoated, Eared
ported and polished
balanced
Chopperfix
Duck's Garage
Duck is offline
post #8 of 38 (permalink) Old 07-06-2008, 04:10 PM
looks like most KAW are the same size...might differ in the length of the stem
post #9 of 38 (permalink) Old 07-07-2008, 02:02 AM Thread Starter
oglejust's Avatar
will a wideglide front end fit?
oglejust is offline
post #10 of 38 (permalink) Old 07-07-2008, 03:07 AM
nope...wide glid is a 1 inch neck..and we have a 1.10" neck
