oil light - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-05-2008, 07:44 PM Thread Starter
oil light
my vulcan fell over while i was washing it ,it fell over on the right side ,now the oil light stays on anyone had a problem like this?
rdonihoo is offline
post #2 of 4 (permalink) Old 07-05-2008, 10:23 PM
Love My Baby
rubyrick's Avatar
Hey, I'm sorry to hear you dropped your bike. Motorcycles are very unstable on the side stand if they're not leaning or leaning only slightly towards the stand. Turning the front wheel all the way to the lock position helps stabilize it.
If your oil light comes on it usually means you're low on oil. Check your oil level and look for leaks. I have a small telescoping mirror that I bought at home depot, and I check my oil while sitting on the bike in a level position. I usually have to lean one way or the other to first see the air/oil line, then sit level again to make sure the oil level is at the top of the window.
Other than that, It's possible that the oil pressure switch was damaged or disconnected, or possibly the oil pump was damaged. But there are many people on this forum much brighter than I who know these bikes really well. Someone will help you, I'm sure.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #3 of 4 (permalink) Old 07-05-2008, 11:41 PM
HAWK
Ccspinner's Avatar
You lost prime on the pump, Try loosining the oil filter till a little oil leaks out.
Tighten it back and start the bike.
I have seen this before, do not drive as you do not have oil PSI.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 4 (permalink) Old 07-07-2008, 10:46 AM
Sky Rider's Avatar
Agree!! One member here totalled his engine because he rode it with the light on. You most likely have an air bubble in the pump and need to "burp" it using the procedure CC described.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
