Gunk engine degreaser? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 08-04-2015, 04:04 AM Thread Starter
Has anyone used it to clean their bikes?
I got an 85 vulcan 700. With a lot of grease and oil on the engine, if any of you vets uses it before can you share some tips on how you go about cleaning you engine?
Aceofspades8759 is offline
post #2 of 10 (permalink) Old 08-04-2015, 10:13 AM
An 85 700? With the black painted engine right?
I'd think the Gunk would remove some of the paint.....
post #3 of 10 (permalink) Old 08-04-2015, 10:55 AM
I use marine soap and a soft brush to clean/degrease the engine because it shouldn't hurt the finish or cause any harm to the paint. It works well for me.
Pressure wash it if it is really grimy, but make sure to dry/clean and use dialectric grease on all the electronic connections afterwards. I also recommend flushing and oiling all the cables after using a pressure washer as well.
post #4 of 10 (permalink) Old 08-04-2015, 12:36 PM
You should see how purdy his bike is
post #5 of 10 (permalink) Old 08-05-2015, 09:59 AM
This is bar none the best engine cleaner out there I used it yesterday and I am constantly amazed. On the worst grime in the crevices, spray it, let it sit a few minutes, hose off. No scrubbing. I get it at the harley shop but it is on Amazon I think.
post #6 of 10 (permalink) Old 08-05-2015, 11:29 AM
Mike DeAngelo's Avatar
Same company has an S100 Engine Brightner.
I've used this and found little difference between the all around cleaner Goofyfoot uses and this one for engines.
2008 Vulcan 900 Classic LT
HID lighting 35 Watt White
Chrome Slotted oval Mirrors
Chilhowee Tank Bra
Barons Big Air Kit
Vance & Hines Twin Slash staggered
EJK Gen 3 Electronic Jet Kit
1991 Vulcan 750 226 miles
Spiegler brake lines
rebuilt calipers, master brake cylinder
Mike DeAngelo is offline
post #7 of 10 (permalink) Old 08-05-2015, 11:55 AM
I've never known Gunk to remove paint, but a pressure washer will always peel off any paint that's already loose.
Get the engine nice and warm, spray on your cleaner and let it sit (don't let it dry), then brush and/or rinse off. Hot water helps if you can get it, a lot of car washes have warm water on the soap setting.
I used Castrol Super Clean on the lower area of my engine and didn't lose any paint. The CSC will take some paints off, but usually just on poorly prepped rattle can jobs. CSC is my go to cleaner for tough grime, but you don't want it on glass or stuff like plastic chrome, clear plastic, etc., and don't let it dry. It's pretty strong at full strength, but can be diluted. It's awesome on tires, vinyl siding, aluminum, engine parts, fiberglas boats ... lots of stuff.
I use dishwashing liquid in hot water to wash the bike and it takes light grease off too.
post #8 of 10 (permalink) Old 08-05-2015, 01:00 PM
I bought my first VN750 new as a leftover. First mistake was taking it to the car wash and pressure cleaning the engine and engine cover. I realized there was a clear coat or clear plastic over the chrome. I not saying not to use the power washer just be careful I guess.
Chilhowee Tank Bra
Barons Big Air Kit
post #9 of 10 (permalink) Old 08-05-2015, 02:37 PM
Pressure washers (when used correctly) are very effective and should NOT harm your paint. Many have dispensers where a de-greaser solution can be used BTW. Of coarse if paint is worn, flaking, or just poorly applied, it will flake off, but a strong hose stream will do the same thing.
You never put the nozzle of a pressure washer that close to whatever it is you are washing unless you plan on stripping paint or scrubbing concrete, fencing, decking...etc.
That being said, I would only use it as a last resort for really grimy stuff that I can't reach to scrub off. Plain old soap, water and a little elbow grease are always the best way to go.
If you don't have time to do it that way, or are just too lazy, then any chemical cleaner can work, but don't think for a minute that repeated uses of chemicals will not eventually harm your paint or clear coat finish.
post #10 of 10 (permalink) Old 08-05-2015, 03:06 PM Thread Starter
Well I just bought a vn700 less the A week ago worked all the kinks out and noticed that it had a lot of grease/oil on the engine and surrounding areas(looks as though the previous owner didn't wash it once while in his possession)
