Reassembly Help Needed.... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 07-30-2015, 10:03 AM Thread Starter
93VN750's Avatar
All -
Since it has been about 4 years since I took my bike apart, the memory is a little fuzzy on some areas.
In particular, the area on the front right of the frame near the radiator cap. I have a brass colored piece of bent metal that somehow hooks into a hole on the frame then secures with a bolt on the other.
Can't remember how to put it ion and what it is supposed to retain.
If anyone has a picture of this area showing how this goes, I'd really appreciate it!
Thanks,
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 7 (permalink) Old 07-30-2015, 10:36 AM
Wink
Sounds like the piece that holds the throttle cables close to the frame.
post #3 of 7 (permalink) Old 07-30-2015, 11:18 AM Thread Starter
93VN750's Avatar
Sounds right, can't figure out how the thing gets attached. Got a picture of the area?
Thanks,
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #4 of 7 (permalink) Old 07-30-2015, 11:35 AM
I'll walk out and look at mine, should be easy enough to describe. Back in a few....
Ok, I may be wrong on this. If that loom holds the throttle cables, it's under the neck cover on mine, because my cables are under the neck cover. Don't have time to pull the neck covers right now, sorry about that.
post #5 of 7 (permalink) Old 07-30-2015, 11:43 AM Thread Starter
93VN750's Avatar
It's definitely under the neck cover. I'm not in a big hurry. It's been apart 4 years, another few days can't hurt.
Could you get this over the weekend?
Thanks,
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #6 of 7 (permalink) Old 07-30-2015, 12:24 PM
Mike DeAngelo's Avatar
Thanks,
Jon
On page 345 of the Clymer manual there's a picture displaying how it's connected. Hope this helps.
2008 Vulcan 900 Classic LT
HID lighting 35 Watt White
Chrome Slotted oval Mirrors
Chilhowee Tank Bra
Barons Big Air Kit
Vance & Hines Twin Slash staggered
EJK Gen 3 Electronic Jet Kit
1991 Vulcan 750 226 miles
Spiegler brake lines
rebuilt calipers, master brake cylinder
Mike DeAngelo is offline
post #7 of 7 (permalink) Old 07-30-2015, 01:08 PM Thread Starter
93VN750's Avatar
I know I have a shop manual and some other, not sure if it's Clymer's, but I'll check tonight.
Thanks!
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
