Rust Removal Without ACID or Electricty - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 07-27-2015, 11:50 PM Thread Starter
Mike DeAngelo's Avatar
I've been using acid to clean rust off of parts making sure I had enough baking powder on hand to neutralize the acid. I have a small dog and I have been extremely diligent. I cannot make any mistakes. So, I'm in Kmart the other day and there's a Gallon of Specialist Rust Remover Soak by WD40. If anyone has used it You'd have to agree it's amazing stuff. It was on sale for 18 dollars a gallon from 28 to 34 a gallon at amazon or other places.
It turns black when exhausted so you can keep using it over and over. Still amazed acid wasn't used and it's bio safe I had to find out what was in it. The MSDS had nothing on the chemical composition so I searched further and I found it.
It's called FMT. Check it out. I'm telling you it's amazing stuff. I let it set for 24 hrs and the part came out 98% clean. I don't know what the ratio is in the WD40 Specialist Rust Remover Soak for water and FMT but I bet it's cheaper to just buy pure FMT and experiemnt. I'm guessing you could cut your cost significantly. Do a search on Amazon.com for "FMT Soak" and low and behold WD40 Specialist Rust Remover Soak comes up.
Here's the link to FMT.
https://www.fastenal.com/products/details/3335321
2008 Vulcan 900 Classic LT
HID lighting 35 Watt White
Chrome Slotted oval Mirrors
Chilhowee Tank Bra
Barons Big Air Kit
Vance & Hines Twin Slash staggered
EJK Gen 3 Electronic Jet Kit
1991 Vulcan 750 226 miles
Spiegler brake lines
rebuilt calipers, master brake cylinder
Mike DeAngelo is offline
