Dumb question about tires - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 06-21-2008, 12:24 AM Thread Starter
This is probably going to seem like a dumb question to most of you, but I'm totally new to bikes and don't know any better...what's the deal with the rear tire? All of the motorcycle tires that I've ever seen have the tread wrap around to the sidewall of the tire. That makes sense to me, because bikes lean and need that extra tread on the sidewall to keep traction. The rear tire on this bike though, doesn't have that. From the looks of the tire, it doesn't appear that you could get much lean out of the bike because you'd run out of tread. I know that's not really the case, but I can't quite wrap my head around how this tire works. Could someone explain it to me please?
2003 Kawasaki Vulcan 750
ramtuff is offline
post #2 of 18 (permalink) Old 06-21-2008, 12:31 AM
I'd have to see the tire to tell ya
85 VN750 basketcase ( yes its a true 750, and no smog controls, its good to be Canadian)
It will have
a rebuilt 96 top end, rebuilt 85 bottom end
degoated, Eared
stripped, lowered, raked, bobbed,
reed valve boxes shaved
ported and polished
balanced
right side dump exhaust
heads and cylinders shaved for compression
looking for smoothbore sidedraft carbs
possibly fat bob tanks
modified vn800 or sportster drag pipes or I'll just make some
Chopperfix
Duck's Garage
Duck is offline
post #3 of 18 (permalink) Old 06-21-2008, 12:38 AM Thread Starter
I would ASSume it's the same style tire that's on all/most of these bikes as these are the stock tires. I could be wrong though. It might be hard to see in the pic, but it just seems like there's a very distinct break between the tread and the sidewall, instead of the tread wrapping around onto the sidewall. But like I said, I'm new to bikes, so this could end up being the dumbest question ever posed on these forums.
ramtuff is offline
post #4 of 18 (permalink) Old 06-21-2008, 12:39 AM
dirtrack650's Avatar
Wonder if his tire is from the dark side...
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 18 (permalink) Old 06-21-2008, 12:48 AM
liljd's Avatar
The tire you have is a standard tire for bikes. If you want the tread to wrap more then get a racing style tire of sorts. It will help with more lean.
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #6 of 18 (permalink) Old 06-21-2008, 12:49 AM
Straight roads are evil
What tire do you have? Which manufacturer and type?
I've run Metzeler ME-880's and Avon Venom tires, both have a lot of tread, can lean it over really far. The Vulcan even railed the corners on the sucky stock Bridgestone tires. It's rare, but I've even scraped the pegs a few times.
Don't worry about leaning, it's what the bike was designed to do. Tires too!
EQPlayer is offline
post #7 of 18 (permalink) Old 06-21-2008, 12:54 AM Thread Starter
I have the "sucky stock Bridgestone tires." Like I said, I know the bike can lean pretty far, but just from looking at that rear tire, it seems to me like you'd run out of tread. My newbie brain just doesn't fathom how that tire design can work.
ramtuff is offline
post #8 of 18 (permalink) Old 06-21-2008, 01:37 AM
if you look at tires with a tread further up the side wall, the tire is more rounded while ours are more square, as you lean the bike over the tire wrinkles giving you more traction...i am talking about the same wrinkle you would get on some M/T 44" Drag slicks, just not as aggressive as that...so little you wouldn't notice it with your naked eye.
post #9 of 18 (permalink) Old 06-21-2008, 05:22 AM
750Doug's Avatar
Looks like a standard rear tire to me. There's enough wrap around to lean it, and it just looks off because it has some sidewall which sport tires have less of.
750Doug is offline
post #10 of 18 (permalink) Old 06-21-2008, 06:10 AM
Daily rider
ksmnet's Avatar
I think that if you were to just lean the bike over while standing still, and watch the tire, you would see you have plenty of tread still on the road. I have the stock Bridgestone tires, and the only time I worry about leaning too much is when I'm turning on a road with more sand or gravel than usual on the surface. This bike hugs the road very well on turns. I mean, it's not a sport bike, but we're not looking to do that type of riding if we own a VN, right?
2017 Indian Roadmaster (current ride)
2003 VN1600A (Traded August 2017 to #1 son for a Bushmaster AR)
2001 VN750 bought 4/19/08 w/2309 miles(Sold April 2010 with just over 12,000 miles)
VROC #33035
__________________________________________________ ________________
Just when I thought I was winning the rat race, somebody moved the finish line!
ksmnet is offline
