positive neutral finder in 700? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-19-2008, 12:20 AM Thread Starter
I'm just about to buy a 1985 Vulcan 700 which doesn't have the positive neutral finder. I know it is in the 1986 750, can anyone tell me if it was also in the 1985 700 or not introduced until the 1986 750?
Thank you
Dan
Danwest is offline
post #2 of 10 (permalink) Old 06-19-2008, 01:39 AM
85 VN 700
curtis97322's Avatar
The 700 has the neutral finder. If the one you're about to buy doesn't have it - it's malfunctioning. (Mine's a 700 and the neutral finder works just fine...)
Curtis - Albany Oregon.
Ammo Can Saddlebags
Hit the 24k mile July 2008
curtis97322 is offline
post #3 of 10 (permalink) Old 06-19-2008, 07:12 AM Thread Starter
I wonder if that is a minor thing or a sign of some major transmission problems developing. I've already made the offer and given a deposit to buy it so I hope it isn't a sign of something major.
Thanks for letting me know.
Dan
Danwest is offline
post #4 of 10 (permalink) Old 06-19-2008, 10:48 AM
San Diego Vulcan Rider
DeForestSD's Avatar
Dumb question. How is the neutral finder supposed to work. I frequently overshoot when moving to neutral just like other bikes I've had. I didn't even know we had a neutral finder. Not that there's anything wrong with that.
86' Vulcan, Stock & Lovin it!
Stator, R/R, splines lubed, ACCT's repl. at 25,200
Just turned 29,000 mi.
95' Vulcan, all stock, 9,700 mi.
John Spangler
DeForestSD is offline
post #5 of 10 (permalink) Old 06-19-2008, 11:33 AM
85 VN 700
As I understand it, the positive neutral finder is a contraption that uses ball bearings to sense whether you are moving or not. When you are moving it more or less "locks out" neutral (you can still get there - it's just harder), when you aren't it makes the first to neutral or second to neutral possible with a full rather than 1/2 kick of the shift lever.
Clear as mud?
Off to my new city job (started monday)... wonder if I'll actually do some work today ;-)
Ammo Can Saddlebags
post #6 of 10 (permalink) Old 06-19-2008, 12:54 PM
ipfreely's Avatar
With the bike in 1st gear, running and not moving, shift to 2nd. If it doesnt go into 2nd gear, the neutral finder is working just fine.
Good luck
Kuryakyn Flame Grips
Bar End helmet locks
Chrome / Gold "Live to Ride Mirrors"
Coastered, Shaved & Jetted
K&N Pod Air Filters
KisanTech headlamp & Taillight modulators
Iridium's
Leather Lyke Hard Bags
Voltmeter, Clock
Stebel Nautilus horn
Slipstreamer SS28
J&M CB Radio
Audiovox CCS-100 Electronic Cruise Control
Mustang Seat, Protac Drivers Backrest
And of course the obligatory stator replacement[/FONT]
ipfreely is offline
post #7 of 10 (permalink) Old 06-19-2008, 09:29 PM
Sky Rider's Avatar
The neutral finder is indeed three very small ball bearings that ride in one of the gear shafts in the transmission. They rely on centrifugal force to keep them to the outside of the shaft when it is turning. Once stopped, they can retract and allow you to get to neutral easier. At least, that's the theory.
As far as it not working, about the only things that will cause that is if the bike has sat for a very long time and the old oil has gunked up the balls. This will stop them from retracting once the bike is stopped. Fresh oil and time should cure this. About the only other thing is if one or more of the balls falls out of the shaft. In that case, you would hear a rattling sound when the bike is running. They are small enough that the screen would probably capture them before they did any real damage but it is also a sign of a worn transmission. You didn't state how many miles are on the bike but the tranny is quite robust and it would take alot of abuse like running alot on worn out oil to cause this. If this is the case, other problems related to poor lubrication will be manifest as well.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #8 of 10 (permalink) Old 06-24-2008, 08:28 PM
I have The 1985 vn700 and it has a green light on the dash for neutral if thats what you mean.
mbsnyder is offline
post #9 of 10 (permalink) Old 06-24-2008, 08:36 PM
liljd's Avatar
Mines an 85 and it does go into nuetral easier when stopped but still can't go a full click or it will go inti second gear. I have to use a half switch myself.
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #10 of 10 (permalink) Old 06-24-2008, 11:28 PM
Sky Rider's Avatar
The green light is only to tell you it's in neutral not the "neutral finder". All the neutral finder is is a slight stop or hesitation of the gear shift when shifting from 1rst to 2nd while the bike is stopped.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
