Different year, same parts? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 06-16-2008, 07:06 AM Thread Starter
Does anybody know if the 86 parts are the same as the 94, more specifically the air boxes, battery case and tool box? I see the parts on e-bay but don't know if they are exactly the same.
vulcan77 is offline
post #2 of 4 (permalink) Old 06-16-2008, 08:12 AM
Those parts you mention should all be the same.
There are a few parts that differ on earlier Vulcan to later ones, such as wiring harness (earlier ones had signal cancelling), forks (earlier ones had air adjustment on front, but should still fit other years), brake master cylinder (square on early models, round on later) and maybe a couple others.
post #3 of 4 (permalink) Old 06-16-2008, 09:26 AM Thread Starter
Thanks for the response, ironically those are all the parts I need.
vulcan77 is offline
post #4 of 4 (permalink) Old 06-16-2008, 10:08 AM
Search Goddess
Dianna's Avatar
Air box, battery case and tool box will fit all years.
If you need the front forks, you can use any year, you just lose the air adjustment on the newer models. You can also swap out the Master cylinder for the newer round one which will also make it easier to get a brake lever (the two go together and the rectangular Master cylinder requires a specific lever)
Wiring harness is a bit trickier though. You can go newer, but you can't go older. If you go newer, you lose your turn signal cancelling, if you go older you have a more serious problem of having an open circuit.
Here's a write-up from the yahoo group about that
A quick update for any of you who might try to outsmart Kawasaki. The
wiring harnesses from 1985-1988 VN700/750 models are *not*
interchangeable with 1989 - Up VN750 models. The 1985-1988 bikes
have both a Reserve Lighting Unit and a Turn Signal Control unit.
Beginning with the 1989 model year Kawasaki simplified the wiring
with the elimination of the Turn Signal Control unit. Because of
this there is no way to overcome the routing of the wires used for
this unit leaving the signal circuit open. I hope this saves someone
else some time!
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
