I rode the bike - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 06-09-2015, 07:17 PM Thread Starter
I rode the bike
I rode the bike for the first time. Can't really tell what issues might be except for my front brakes keep locking down. I am not really sure what is wrong with the brakes unless I need new lines and possibly the master cylinder needs rebuilding. Aggravating as every thing works on it until I pull the bike out of the building and ride. Well I have had it this long without riding it, might as well wait a little longer and get it right.
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 12 (permalink) Old 06-09-2015, 08:42 PM
Might have rings of crud around the pistons in the calipers
post #3 of 12 (permalink) Old 06-09-2015, 08:49 PM Thread Starter
if I pull the cylinders out of the caliper, what am I going to see? Will I destroy anything and have to replace it?
Richard
post #4 of 12 (permalink) Old 06-09-2015, 11:03 PM
Competent Noob
Did you verify fluid was squirting back up into the master cylinder through the tiny hole when you released the brake level?
1995 Vulcan 750
Purchased 5/3/2015 w 10,600 miles
No mods I'm aware of
DieselPlower is offline
post #5 of 12 (permalink) Old 06-09-2015, 11:05 PM
Competent Noob
If you pump the brake lever until the piston comes out, what you will find is a bunch of fluid behind it. You can empty it and clean everything. There should be 2 rubber rings in each cylinder.
1995 Vulcan 750
post #6 of 12 (permalink) Old 06-09-2015, 11:46 PM
I usually pump the piston(Yup I said it.lol) till it's past the crud line,clean off da crud,and usually I'm done there
post #7 of 12 (permalink) Old 06-10-2015, 07:39 AM Thread Starter
You know I did do that. I pumped the piston until it showed good clean cylinder but didn't clean the crude off. I guess I will do that.
Also I didn't see anything coming back out the master cylinder. I am thinking that since one side works that the master cylinder is working for at least one side, maybe I need to clean that hole a little more. Don't know but worth a try.
Richard
post #8 of 12 (permalink) Old 06-10-2015, 01:54 PM
Competent Noob
I've been suggesting for at least a week to clean out the little hole and ensure fluid comes back out of it. When I was having brake problems I could get the left side piston to push in with a clamp pretty easily but I could not budge the right side no matter how hard I tried.
1995 Vulcan 750
post #9 of 12 (permalink) Old 06-10-2015, 04:32 PM Thread Starter
Could you get the left side to release also after pressing the lever and releasing it? Also I took your advice and cleaned that hole but apparently I didn't clean it enough. Do I need to take the fluid out and clean it or just stick something down there to clean it?
Richard
post #10 of 12 (permalink) Old 06-10-2015, 05:55 PM
Competent Noob
The left side was not clamping tight to the caliper like the llrightbside was. I also believed I had cleaned the hole well, but I had to do it a second time. I had all clean fluid the second time. I stuck a needle in the hole as deep as I could several times and haven't had any problems since. I could be wrong. This may not be your problem. But your symptoms are exactly like mine. Sorry if my previous post seemed rude. I had a stressful morning at work, so my apologies.
1995 Vulcan 750
