Im sol, need help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 05-28-2015, 06:38 PM Thread Starter
Dirt to road
duraholiday's Avatar
Im sol, need help
Was coastering my bike when the ****in bottom bolts on both sides sheared off. If you have advice tell me if you have advice and can help in person pm me if your in the flint michigan area.
Thanks
Holiday
Project Bike 92 VN750
Days running: 0
Project Pictures http://s1116.photobucket.com/user/dieinghost/library/
Up coming Projects:
NOW- Getting it running....
Winter of 2015- Bobber Build
duraholiday is offline
post #2 of 13 (permalink) Old 05-28-2015, 06:55 PM
2000 VN 750 Senior Member
Start spraying them with Blaster or WD 40. Do it several times and give it time to work itself in. Using a small punch. Tap a hole somewhere towards the outside of the bolt. Do this so the hole (indentation) is running towards the base of the bolt. Next use the same punch and tap against the hole in a motion so as to turn the bolt in the correct direction to remove it. This may take a significant amount of lubricant to work. If there is any portion of the bolt outside the threads try to grip it with Vise Grips after filing two flat spots for better gripping power. Good luck.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is online now
post #3 of 13 (permalink) Old 05-28-2015, 07:10 PM
If you get desperate, post for a mobile mechanic on Craigslist. A buddy got a bolt removed like that for $20, and the guy came to him.
post #4 of 13 (permalink) Old 05-29-2015, 12:00 AM
Chucklehead
dragon159's Avatar
Same thing happened to me and I went a different (cheap) route. If you look under where the coaster goes you will see the only port is easily filled with a 1/4 inch set screw if carefully tapped 1/4-20 tap. Seal it with a little locktite and then install the coaster with the upper bolt and crazy glue a head over the lower bolt hole .... no leaks and still looks right.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #5 of 13 (permalink) Old 05-29-2015, 08:45 AM
I'd say drill it. You need to start with the smallest drill bit you can and very gradually step up until you can either get an extractor in there or you get enough of the bolt removed that it can be bent or turned out. Lemme check my schedule. Send me a pm with your cell phone number and I'll shoot you a text.
post #6 of 13 (permalink) Old 05-29-2015, 10:00 AM Thread Starter
Dirt to road
Tried but didnt work, the bolt wont move at all
Days running: 0
Up coming Projects:
post #7 of 13 (permalink) Old 05-29-2015, 10:01 AM Thread Starter
Dirt to road
Idk how i feel about taping it, i dont like the idea of metal in my cylinder
Days running: 0
Up coming Projects:
post #8 of 13 (permalink) Old 05-29-2015, 10:58 AM
Crowley
crowley1027's Avatar
Just use the screw, don't tap it. It's aluminum, so the bolt will cut itself through it. Get one with self tapping tip.
crowley1027 is offline
post #9 of 13 (permalink) Old 05-29-2015, 11:06 AM
I've heli-coiled spark plug holes with the head on the engine, any chips must have been blown out the exhaust, since nothing bad ever happened. Some grease on the flutes of the tap will trap most of the chips.
Doesn't look too easy no matter what, but usually once you get a hole through the broken bolt, the tension on the threads is released and the broken piece will spin out.
There are also left-hand drill bits made for this, could be hard to find though.
Heat can help too, sometimes I'll heat the threads then let oil wick in as it cools.
post #10 of 13 (permalink) Old 05-29-2015, 11:39 AM
Crowley
Heat the bolt with some easy local heat like small torch, then hit it with candle wax. Miracle stuff
