Noise on take off - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-23-2015, 09:17 PM Thread Starter
AndrewGilbert's Avatar
Noise on take off
I've put about 1200 miles on my VN so far and the only thing that it does that doesn't seem right is that when you go to take off, especially when cold starting off, it makes a "brrruhh" noise. It sounds almost exactly like a hydrostatic mower taking off and the pump grunts at you. It only does it for a quick second and then it quits. Doesn't do it shifting gears or hitting throttle in 1st. I can't tell where it's coming from. Not really sure what it is. If my super awesome description doesn't do it, I can get a vid of it making the noise tomorrow. Happens every day.
2006 Vulcan 750
Bone Stock
2000 Honda XR650L
Wiseco 10.4:1
Pirelli Scorpions
AndrewGilbert is offline
post #2 of 6 (permalink) Old 05-23-2015, 09:42 PM
JM2001's Avatar
Do a search for " coffee grinder syndrome ". Very common. Also check this https://www.vn750.com/forum/showthrea...inder+syndrome
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 6 (permalink) Old 05-23-2015, 09:54 PM Thread Starter
Thanks, JM2001! That's it exactly. I believe I'll do a thorough oil change and see if it improves. If that doesn't do the trick I'll do the mod. I thought it may be the clutch but I just couldn't put my finger on where the noise was coming from. The guy I bought it from said he did an oil change at 1600 with Lucas; it may not be a great fluid for the clutch.
2006 Vulcan 750
Bone Stock
2000 Honda XR650L
Wiseco 10.4:1
Pirelli Scorpions
post #4 of 6 (permalink) Old 05-23-2015, 10:06 PM
JM2001's Avatar
Before doing an oil change put about 4 ounces of SeaFoam into the crankcase. Warm up the engine at idle for about 10 minutes then ride the bike for about 10-15 miles. Drain the oil and put in a good motorcycle oil. I use Castrol 4T 20-50 motorcycle oil. I got rid of the coffee grinder noise.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #5 of 6 (permalink) Old 05-24-2015, 10:35 AM
Wink
X3 on coffee grinder.
It can also help to work the clutch lever a few times while it's warming up, before you take off.
Seafoam: Come to think of it, I haven't seen coffee grinder this season, last year I ran a dose of Seafoam for 200-300 miles, because I thought it might have a sticky intake valve. Seems like both problems are gone now.
Long story but ... Coffee grinder dumped me on my butt the first year I rode mine. Be careful with it. Previous owner got dumped too.
post #6 of 6 (permalink) Old 05-24-2015, 03:56 PM
As Sprockster said, work the clutch lever a bit before taking off (while it's warming up). First few takeoffs I just let it out real easy. No oil changes etc made it ever go away completely. I'll be drilling holes in the basket this summer when I'm swapping the plates and springs for a perm fix.
