Just got my Vulcan back from shop: - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 05-11-2015, 02:33 AM Thread Starter
OrlandoVulcan's Avatar
Send a message via Skype™ to OrlandoVulcan
OK, so I decided to forego the DIY carb clean and took my bike into a fairly reputable shop here in town for that purpose.
On top of the carb clean, I discovered that whoever had the bike before put something in the coolant reservoir that they weren't supposed to, so I had to flush that, had to put in a new bladder and other various parts for the carbs, had to get a new front tire, and a few other minor things. Now, the bike runs smoother. The choppiness is gone. When they went into the bike, they somehow broke the return cable, and I have a new return cable and throttle cable on order.
That being said, although the bike runs smoother, it seems to have lost some power. Is this normal for a carb clean? Could the return cable have anything to do with that? Before I took it in, she was actually pretty responsive out of the gate. From zero to 40 or so, I could pretty much take most cars. Now, I have to twist the throttle a lot more to get her going. Is she still getting used to the carbs being cleaned like they were? Will this change once the new cables are installed this week?
It's not horrible, but it's noticeable to me because I remember how she was before.
Mike's Moving
Orlando, Florida
2002 VN750
Need to know the part number to a confirmed 18mm Deep Well socket bit to change your VN750's spark plugs?
Craftsman Part Number 50728
OrlandoVulcan is offline
post #2 of 19 (permalink) Old 05-11-2015, 06:59 AM
rsavant's Avatar
I experienced a similar problem when I shipped my carbs for a "professional" rebuild. The bike runs great, plugs look normal, but there is a noticeable lack of power. I've done all I know to do and haven't found anything. It's still strong, but not like before the carb work. Wish I could offer some advice but I have none. If you come up with anything, I'd like to know.
"Katie"
2002 VN 750, stock except for accessories
Mustang seat
Super Bright LED brake strobe on trunk
About 25k miles
All drive train maintenance performed, drive shaft coupler replaced
Way more experienced at pulling VN 750 carbs than I ever wanted to be.
TOC ACCT rebuild kits installed
Pick up coil mod
Cooling system flushed, refilled with fresh coolant
Petcock rebuilt
VN sold, current steed Honda ST 1300
rsavant is offline
post #3 of 19 (permalink) Old 05-11-2015, 07:55 AM Thread Starter
Did that lack of power stay gone? I assume from the way you said it, it did. Was kinda hoping this would be a "phase" until it works through the system or something, or that it was somehow related to the broken return cable, which hasn't been fixed, yet.
Mike's Moving
Orlando, Florida
2002 VN750
post #4 of 19 (permalink) Old 05-11-2015, 08:48 AM
JM2001's Avatar
No it's not normal for a carb clean. If the carbs were cleaned and put back together properly I would say you have a fuel delivery problem. Either a low fuel level in the float bowl or a problem with the float needle valve. Did they adjust the float level to spec? Are the butterfly valves opening fully?
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 19 (permalink) Old 05-11-2015, 09:21 AM Thread Starter
I couldn't accurately answer those questions because I didn't do the work, and I don't know the terminology. Is this something I can check for myself?
Mike's Moving
Orlando, Florida
2002 VN750
post #6 of 19 (permalink) Old 05-11-2015, 09:54 AM
JM2001's Avatar
They should have checked and adjusted the floats when the carbs were off the bike. Same goes for the butterfly valves. You can check to see that the accelerator cable is opening the throttle control plate fully against the stop. That will show you that at least the cable is calling for full throttle.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #7 of 19 (permalink) Old 05-11-2015, 10:27 AM
I believe the Throttle Return Cable is a tad longer than the Throttle Cable.
Is it possible the shop broke the Throttle Cable, then swapped with Throttle Return Cable..........not knowing they are different lengths ?
Now the bike throttle does not allow true WOT ?
.....just a theory......
WilliamTech
post #8 of 19 (permalink) Old 05-11-2015, 10:49 AM
Crowley
crowley1027's Avatar
Any difference in cable length can be adjusted. I hooked mine up backwards and couldn't tell
crowley1027 is offline
post #9 of 19 (permalink) Old 05-11-2015, 10:54 AM
JM2001's Avatar
Good thought. The accelerator cable is shorter. Worth checking out.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #10 of 19 (permalink) Old 05-11-2015, 10:56 AM
JM2001's Avatar
What about the cable guide on the accelerator cable?
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
