Tank bolt - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-09-2015, 07:20 PM Thread Starter
Tank bolt
Can someone tell me what the bolt on the tank in front of the battery size is and also the bolts on the side of the tank. I am not sure what goes in those holes but someone before me has put pvc pipes pieces in there as spaces. I guess it will work unless it melts.
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 4 (permalink) Old 05-09-2015, 08:41 PM
Crowley
crowley1027's Avatar
M8 fine thread I believe. I know it's m8
crowley1027 is offline
post #3 of 4 (permalink) Old 05-09-2015, 08:45 PM
the rear bolt is same thread, but longer than the side bolts (the rubber insulator is thicker on the rear than the sides)
michiganteddybear is offline
post #4 of 4 (permalink) Old 05-09-2015, 10:20 PM
heaney750's Avatar
side bolts r 2.5 inch rear one is 3 inch go to an auto parts store tell em u want a set of sway bar bushings for any car cut one in half and use a half on each side with a flat washer on the outside cost about 8 to 12 bucks
heaney750 is offline
