2005 vulcan 750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-13-2015, 12:52 PM Thread Starter
2005 vulcan 750
I got a 2005 kawasaki vulcan 750.I had the carbs and new tires and plugs put in it. When I went to fill it up at the gas station--I cut it off and filled it up. When trying to restart--it didn't want to start-i throttled it and even did the choke--it backfired like a gun went off--then kept starting and finally cranked.I haven't a clue what the problem is. I need help. I have no problems cranking it cold. Only when it is hot. I rode it 18 miles before I cut it off. Thanks for letting me join.
Dean Hasty is offline
post #2 of 8 (permalink) Old 04-13-2015, 01:06 PM
ok, the hot start issue is pretty common, there are a couple things to check/fix.
1st. check the battery, we recommend using an AGM battery, instead of a flooded wet cell (older, more common technology).
2nd. pickup coil mod. move the pickup coils for the ign a little closer to the flywheel. those of us who have done it end up at .020 inch. makes a HUGE difference in hot start. (I know this fixes a lot of them, it fixed mine, exactly the same symptoms you have).
michiganteddybear is offline
post #3 of 8 (permalink) Old 04-13-2015, 01:09 PM Thread Starter
thank you --i will tell my mechanic to try this.
post #4 of 8 (permalink) Old 04-13-2015, 03:55 PM
You can do it. See below. Very simple.
https://www.vn750.com/forum/showthrea...ck+up+coil+mod
post #5 of 8 (permalink) Old 04-13-2015, 05:14 PM
Also a lot of us use the NGK iridium plugs, when I got my 1st bike I put in the AGM battery and plugs and never had a hot start issue.
post #6 of 8 (permalink) Old 04-13-2015, 08:29 PM
Same here.
post #7 of 8 (permalink) Old 04-13-2015, 08:34 PM
X2 ....never did the pickup mod, but my bike started great no matter hot or cold... That AGM battery by itself did pretty good. If you have a wet cell, that's likely your problem....
post #8 of 8 (permalink) Old 04-13-2015, 10:06 PM
Kevinf's Avatar
I have an AGM battery and Iridium plugs and mine hot starts just fine without backfire. Run some Seafoam or Star-tron through too if you haven't already.
Kevinf is offline
