cold starting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-18-2015, 08:46 PM Thread Starter
cold starting
Are these bikes hard to get started? Are they cold natured I guess is what I am asking. I got it started but it won't rev up and shut off.
mrseedsower is offline
post #2 of 7 (permalink) Old 03-18-2015, 09:26 PM
Sounds like maybe the petcock was off, it stopped getting fuel, or needed more choke?
They usually need the choke on for a while when it's cooler. I go full choke, slide the lever as the rpm comes up and keep the rpm about 1500-2000 until it starts warming up. If I just turn the choke off, it will die shortly and won't start without choking again.
It can take a few cranks to get the fuel going if it sits a few days.
Sometimes after warmed up then parked 20 minutes, I use full choke to fire it quicker, and as soon as it fires the turn choke off .
post #3 of 7 (permalink) Old 03-18-2015, 09:30 PM Thread Starter
I don't have the petcock on the bike yet. I actually only have the gas lines on it and are filling the hoses up with gas. But when I look at the hoses they still have gas in the tubes.
post #4 of 7 (permalink) Old 03-19-2015, 02:01 AM
how do you not have the petcock on the bike? without the petcock theres just a giant hole at the bottom of the tank
1996 VN750
V&H pipes
HID headlight
Ear shave
Clubman Bars
Matte black plasti-dip "paint" job.
yousername is offline
post #5 of 7 (permalink) Old 03-21-2015, 12:49 AM Thread Starter
I have whole tank off the bike and I have long gas lines on the carbs. I use a small tank with a small nozzle that I fill the gas lines with. Then refill as I need. I am going to rig a bottle with a t in the lines to give constant gas to the carbs but I haven't done that yet.
Grace and Peace to you!
Richard
post #6 of 7 (permalink) Old 03-21-2015, 12:04 PM
If you got it started but it "won't rev up" you have a problem with your carbs.
Not sure what you mean "and shut off"....the bike won't shut off?
post #7 of 7 (permalink) Old 03-21-2015, 02:56 PM Thread Starter
Knifemaker I mean once I rev it up the bike stops running.
