Can't get the side cover off my new 750? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 04-26-2005, 11:59 AM Thread Starter
Angry Can't get the side cover off my new 750?
Can anyone tell me what the correct tool is to unscrew the huge cover screw? I've bent two quarters trying to loosen it after spraying it with wd-40???
youn2433 is offline
post #2 of 10 (permalink) Old 04-26-2005, 07:03 PM
Re: Can't get the side cover off my new 750?
Mine was frozen. I had to use an impact wrench with a big Philips bit in it.
Bruce is offline
post #3 of 10 (permalink) Old 04-27-2005, 01:03 PM Thread Starter
wow thanks for the reply
youn2433 is offline
post #4 of 10 (permalink) Old 04-29-2005, 12:10 PM
Sgt Mike's Avatar
The left side cover screw on my 2005 VN750 was so tight that a 12' screwdriver with an adjustable wrench couldn't move it. The dealer had to drill it out, run a tap in the threads to freshen them up. it was tapped undersize at the assembly plant and the screw forced in.
Semper Fi & Ride Safe
VROC 14523
Sgt Mike is offline
post #5 of 10 (permalink) Old 04-29-2005, 05:26 PM Thread Starter
WOW...unreal...Now I understand...I guess I'll let them remove it at service time..Thanks
youn2433 is offline
post #6 of 10 (permalink) Old 04-30-2005, 07:18 AM
youn2433,
The side cover screws are designed to be loosened and tightened with the flat part of the ignition key, either the end or one side. The side works best.
If they are frozen in place from non-use, the key handle may not do it.
Maybe you can get some WD-40 on the screw threads by removing the seat and getting to the threads from the inside?
CD in Anadarko, OK
Ol Poop is offline
post #7 of 10 (permalink) Old 05-01-2005, 05:53 PM Thread Starter
Cool..didn't know about the key....will try..thanks
youn2433 is offline
post #8 of 10 (permalink) Old 05-02-2005, 02:32 PM
[I]The key! Dang It[/I], the key is the trick! I would have never guessed. Mine aren't stuck and I have had them off a few times, but finding the right screwdriver so as not to mess up the screw head is a PIA!
I will tell everyone I know about the key trick. BTY have we mentioned this on the yahoo group? I may have missed that post.
Hoot is offline
post #9 of 10 (permalink) Old 05-02-2005, 07:14 PM
I never thought about the key either. I always used some change, or a very large screw driver. But the key makes perfect sense. Reminds me of the M1 carbine. You can tear it down with a bullet casing. How clever.
Ride Safe
Wayne
gnon2705 is offline
post #10 of 10 (permalink) Old 05-05-2005, 04:23 PM Thread Starter
Finally got it off by grinding down a large washer the same thickness as the key. I ground it until it was several inches wide and then with the help of wd-40 and vice grips was able to loosen it. Then applyed some grease on threads so it won't happen again.
youn2433 is offline
