Is this a Good Deal? Good starter bike? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 01-04-2015, 07:04 PM Thread Starter
I have found a 2006 Vulcan 750 for sale for 2300 dollars. It has 1100 miles on it. Looks awesome from the pictures. I am 6'3 with a long inseam. Totally new to motorcycles. Would this be a good bike for me to modify to fit me and ride for a few years on short rides? What about for my dad, who is getting back into riding? He is 6'1. We both weight around 165 lbs. Also worried about Stator replacement though we very mechanically inclined and work in mechanical field. Wondering if we should go strait to a vn 900 though cash is tight.
BOB764 is offline
post #2 of 9 (permalink) Old 01-04-2015, 07:30 PM
Welcome to the nuthouse. These are good bikes and run real well.read the Vulcan verses. I would make sure it's charging.might also wanna introduce yourself in the newbie section
post #3 of 9 (permalink) Old 01-04-2015, 11:38 PM
Mod
Birdhunter02's Avatar
I'm 6' 2" and while it felt fine, when looking at pictures of me on the bike, I looked like a goon. No problems with power, though. They are fine bikes and there are plenty of parts out there.
2003 1600 Classic
Sold
900 Seat Mod
Iradiun Plugs
V and H Cruzers
Windshield with Lowers
LED Tail Lights
Saddle bags
Chads Floor boards
Highway pegs
Birdhunter02 is offline
post #4 of 9 (permalink) Old 01-04-2015, 11:47 PM
Paid 1100 for my 86 a few years ago. It was my first bike, worked out fine. I'm 6'2-6'3 - It's not as big as some bikes but I don't think I look ridiculous on it.
Check the charging with a multi-meter. You want to see north of 14v DC @ 5000RPM directly on the battery.
For that year and mileage, you should be fine as long as she's in running condition. The tires may be at the point you want to change them, just due to the age.
post #5 of 9 (permalink) Old 01-05-2015, 01:42 PM
I'm 6'0" and had to get used to the short leg room. Highway pegs would pretty much take care of that though.
post #6 of 9 (permalink) Old 01-07-2015, 07:48 PM
Concert connoisseur
wib714's Avatar
11000 miles and age of tires if original set I would replace, make sure you do a spline lube while you have the rear off!! quick easy procedure that will save you tons of hardship on this bike! I would do it personally and not rely on a shop to tell you they did it!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #7 of 9 (permalink) Old 01-07-2015, 11:32 PM
Got any pics?
post #8 of 9 (permalink) Old 01-08-2015, 02:22 PM
Well, did ya get it?
post #9 of 9 (permalink) Old 01-17-2015, 11:59 PM
1100 or 11,000? If 1100, it's a brand new bike, go for it. If 11,000, it may already have some spline damage because Kawasaki did not lube the splines at the factory. Replacing the stator is a lot of work, but not difficult, just time consuming. With the exception of removing and reinstalling the carbs, the Vulcan 750 is no more difficult to work on than any other bike till you get deep inside the engine. And I have found a couple of tricks that make removing and installing the carbs a lot easier than it was the first time I did it.
If the tires are good (good tread and no cracks) I would probably go ahead and wear them out. But I don't recommend that. I ride mostly straight up on interstates. As tires age, they harden (which can actually make them last even longer) but they don't have the traction of a newer tire, you can lose traction on slippery surfaces or from leaning the bike over a bit to far.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
