When is a 750 a 1500? (Winter Project) - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 26 (permalink) Old 12-22-2014, 10:58 AM Thread Starter
GloryRider's Avatar
When you trade it for one!
I traded the vn750 for this '95 vn1500...
https://www.flickr.com/photos/357838...7649444442518/
As far as I know, the original owner bought it in 1995, rode it a little more than 6000 miles, and then lost it in a divorce settlement... the wife then gave it to someone else as payment for some work, and it sat in his yard for a while... the guy I got it from wanted to restore it, but didn't have time or a place to work on it...
So from what I can tell, it's just an old bike with low miles that needs some clean/tune up...
I know its going to need new tires, and a couple other minor parts...
What would y'all recommend doing first to get it back on the road?
Thanks,
Matt
GloryRider
Atlanta, GA
Current Ride: 1995 Vulcan 88 (1500A9)
Purchased Dec. 2014
approx. 6,800 miles
Previous Bike: 2000 VN750 "Glory"
With homemade stator
Details on stator build here
"Four wheels move the body. Two wheels move the soul"
"You live more in 5 minutes on a bike like this going flat out than some people live in their lifetime." - Burt Munro
GloryRider is offline
post #2 of 26 (permalink) Old 12-22-2014, 11:29 AM
Dent in tank....check for rust. Fill with fresh gas.
I'd check those tires.... might need a new set (tires have dates on them)
Where is the seat?
Change the oil. New Battery? Check coolant --flush and replace.
Then try starting it.....
post #3 of 26 (permalink) Old 12-22-2014, 11:46 AM Thread Starter
GloryRider's Avatar
Yeah, the tires definitely need to be replaced...
The seat was chewed up by one of the previous owner's dog... the guy I got it from gave me a new seat, it's from a slightly newer model 1500, so I'll have to adapt it a bit...
The gas in it smells old... is there a way to flush/clean it out before putting fresh gas in it?
GloryRider
Atlanta, GA
Purchased Dec. 2014
approx. 6,800 miles
post #4 of 26 (permalink) Old 12-22-2014, 12:02 PM
Syphon the gas out with a clear hose and into a filter screen to see if there is any rust at the bottom of the tank.
post #5 of 26 (permalink) Old 12-22-2014, 12:04 PM
You likely need to remove the tank (it's fuel injected?)
Drain it into a gas can. Pour some out first from the gas cap to see if there are rust flakes in it. I'd rince it out with seafoam.
post #6 of 26 (permalink) Old 12-22-2014, 12:15 PM Thread Starter
GloryRider's Avatar
It's not fuel injected... Do you think I need to clean out the carbs?
GloryRider
Atlanta, GA
Purchased Dec. 2014
approx. 6,800 miles
post #7 of 26 (permalink) Old 12-22-2014, 12:36 PM
Yes.
post #8 of 26 (permalink) Old 12-22-2014, 05:49 PM
Sweet!yea I'd clean the carbs.I'd look for a meanie seat
post #9 of 26 (permalink) Old 12-28-2014, 09:03 PM
Nice old BUBF. Haven't seen one for awhile. You should be able to get the correct seat on eBay, even if it is not in perfect condition it can be reupholstered.
The carbs will definitely need to be cleaned, and if ethanol was left in it, may need more than that. I would remove the tank, pour out anything that was in it, then pour in a gallon of Superclean, and shake it around. Let it set for a few hours, then shake it again. Do this several times, then pour it out and rinse the tank with water, then pour in about half a gallon of kerosene, shake it good, and pout it out. The kerosene will leave a protective oily coating on the inside. If it is not rusted, or just barely rusted you should be ok. If it is badly rusted, things get a bit more complicated.
You will either need to replace or rebuild the petcock, replace the fuel lines, and probably some of the rubber parts in the carbs. If you haven't turned the engine over yet, I would pour some transmission fluid in the spark plug holes first, and let it soak. If the rings are stuck, and you try to turn it over with dry cylinders, it will do some damage.
If the engine starts and runs, and it seems to shift ok, then I would tear it down, lube the splines, the swing arm bearings, the steering head bearings, change the final drive, engine, and fork oil, lube all the cables, and just give it a good going over in general. With only 6,000 miles on it, that bike should give you years of nearly trouble free use. The old style 1500 is not as trouble prone as the 750, and easier to work on. It's also fairly rare now. 1500 and 1600 Classics are everywhere, but the old 1500 has virtually vanished. While it's fairly rare, it's not a collectors item. If it were mine, I would just put it back together, and ride it as is, leaving the original patina and even the dent in the tank as is. Makes it looks like it has actually been ridden rather than being a trailer queen.
I used to be one of those types that was constantly cleaning and polishing my bikes, now I see cosmetic wear and damage as a badge of honor. You can look at a row of bikes, and tell the ones owned by real riders. They will be the scratched and dirty ones.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #10 of 26 (permalink) Old 12-29-2014, 12:32 PM Thread Starter
GloryRider's Avatar
Thanks Knifemaker, OldDoc, and Jerry!
I'll work on all those suggestions... I'm hoping to get this thing up and running soon!
GloryRider
Atlanta, GA
Purchased Dec. 2014
approx. 6,800 miles
