Good Motorcycle Shop in Indianapolis? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 10-27-2014, 09:21 AM Thread Starter
I'm a new VN750 owner and my bike is having issues with sputtering at 35-45% throttle. I am looking for a good shop to take my bike to in Indianapolis that can diagnose and fix the issue(s). Any suggestions?
Thanks!
transamdude95 is offline
post #2 of 14 (permalink) Old 10-27-2014, 11:30 AM
are you mechanically inclined at all? if so, no need spending $ at a shop, we can help ya here!
michiganteddybear is offline
post #3 of 14 (permalink) Old 10-27-2014, 01:32 PM
I agree with teddybear.there is a lot of knowledge on here and lots who wanna help.
post #4 of 14 (permalink) Old 10-27-2014, 02:06 PM
+2. Not much on these bikes is very complex and most repairs can be done with pretty standard tools.
RobertGary1 is offline
post #5 of 14 (permalink) Old 10-28-2014, 11:57 AM Thread Starter
Thanks for the quick replies. You may have convinced me to try to tackle the issues my bike has instead of going to a shop. I had a bad start on the bike as one of my spark plugs crossthreaded. I was able to get a back tap to fix it enough to get the spark plug back on, though. The issue the back has had since I bought it is bad hesitation/stuttering at 30-40% throttle, particularly in the higher gears and at 45+mph. It seems to be a common symptom resulting from potentially multiple problems. I'll make a separate post with an appropriate subject.
post #6 of 14 (permalink) Old 10-28-2014, 12:58 PM
Its common to need to clean the carbs. Although the symptoms you describe sound a lot like what I experienced when the carb vent tub came out of the back of the right filter.
-Robert
post #7 of 14 (permalink) Old 10-28-2014, 02:10 PM
+1 robertgary, for stock air filters
also, some details as to any modifications have been done, or expect to be done is needed..
example would be is it ear shaved (removing the air box and stock filters and using pod filters instead)? different exhaust? different Jets in carbs?
I bring that up, because one of the causes of your symptoms may be a result of an ear shave.. regarding the carb vent hose. it needs to be in dead air (up under tank on a frame rail is good, as is plugged into the plastic cover for the fuel sender)
post #8 of 14 (permalink) Old 10-28-2014, 11:48 PM Thread Starter
I do recall the carb vent tube in the right filter. I cut it at 45 degrees and put it back in place where I found it. It was not "plugged" into the air filter housing though... I'll see if that corrects the issue as soon as I get some decent weather.
As for mods, there really appear to be none. The bike is a '94 with 6,000 miles and it seems safe to assume the prior owner would not have modded the bike. I did pour some seafoam into the gas tank to do some cleaning. Any suggestions on how/where to pour this into the carb directly?
post #9 of 14 (permalink) Old 10-29-2014, 01:06 PM
Welcome aboard!
If you really want to pour some seafoam into the carbs, you can disconnect the fuel lines from the petcock, drain the fuel bowls by loosening the drain screws at the bottom, and retighten and fill with seafoam. It should do all it will within about 24 hours.
2000Vulcan750 is offline
post #10 of 14 (permalink) Old 11-03-2014, 09:55 PM Thread Starter
The bike is now fixed! It was the carb vent hose in the right air filter box. I tucked it into the slot at the inside top of the airbox and now I have no loss of power at any throttle level. I finally got to feel what my bike is capable of and I love it! Thanks for the help!
