It is alive!!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 10-10-2014, 04:17 PM Thread Starter
Concert connoisseur
wib714's Avatar
It is alive!!!!
Its been nearly a year and a half since I tore it down, replaced the balance dampers as suggested by Lance 328 many moons ago. Did the Tuxedo stator cover mod (thanks Glen c for the plate). seems all good, fired on about the second third try, ran a little rough at first but smoothed out quick. took it for a buzz down the road and it felt great!!!!!
clutch seems to slip a little and it didnt before, not sure if I can adjust that at the final drive a little or at the handle bars, have a few looose cables to tighten up, adjust the rear brake light now I just need tags and insurance just in time for the snow probably!!! trying to upload a vid but photobucket doesnt seem to be cooperating!:
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #2 of 15 (permalink) Old 10-10-2014, 04:28 PM
Nice job Wib!
post #3 of 15 (permalink) Old 10-10-2014, 04:31 PM
Good job man. There is a little adjustment for the clutch at the handlebars and the barrel adjuster by the foot peg.
post #4 of 15 (permalink) Old 10-10-2014, 05:22 PM
Chuck A.'s Avatar
Chuck A. is offline
post #5 of 15 (permalink) Old 10-10-2014, 05:45 PM
Good for you man......just in time to put it up for the winter!
Hey, I ride in cold. (No snow however)
post #6 of 15 (permalink) Old 10-10-2014, 07:17 PM Thread Starter
Concert connoisseur
wib714's Avatar
now that I work 12 miles from home I'll ride, when I worked here before I rode it in it was 20 degrees one morning, the afternoon it was like 35 40 but even 12 miles in 20 degrees I was fine except for my hands, thought about paintint a set of quad handguards to put on in the winter. it would help a lot
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #7 of 15 (permalink) Old 10-29-2014, 01:14 PM
Awesome!! Glad to hear she's back on the road!
2000Vulcan750 is offline
post #8 of 15 (permalink) Old 12-16-2014, 12:25 AM
Make sure you have the clutch actuator arm lined up properly where the splined clutch shaft comes out of the engine. It has to go a certain way, or you will never get the clutch adjusted properly. Hopefully you did the stator cover mod with the cover off the bike.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #9 of 15 (permalink) Old 12-16-2014, 01:17 PM Thread Starter
Concert connoisseur
wib714's Avatar
I went ahead and parked it for the winter and still need to adjust the cluch, I did remove the engine while doing the mod and would suggest it to anyone because that is a lot of shavings and metal dust to grind those covers down! it all went back pretty smoothly, grinding down the outer cover ribs was the worst part I think to get it to lay flat so I only needed the rubber oring and no gasket sealer there
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #10 of 15 (permalink) Old 12-16-2014, 01:32 PM
What does it to, "park it for the winter"? Sounds horrible.
