handle bars - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 02-14-2008, 12:04 PM Thread Starter
Post handle bars
son wants to change handle bars to more of a drag type bar. anyone done this or any other bar replacement ideas? basically he wants them lower but of course clearance is also an issue. thanks in advance for any help.
steedridr is offline
post #2 of 12 (permalink) Old 02-14-2008, 01:43 PM
BMan23777's Avatar
Highway hawk makes a set,Drag sport bar If I remember.Had them on my bike with no clearence issues.I got them from The Biker Barn I think.
Brian Manchester
'89 "GRIMM"
04 durango AWD
BMan23777 is offline
post #3 of 12 (permalink) Old 02-14-2008, 02:02 PM
That was the first thing i did for Lulu was change out the bars. It was quite a improvment to how the bike handeled.
these are on lulu
http://www.cyclepages.com/ProductDet...ductID=4014067
LurchChaos is offline
post #4 of 12 (permalink) Old 02-14-2008, 03:02 PM
Scoop's Avatar
these are on lulu
Did you have to shorten the cables?
I put some dirt bike handlebars on mine just to see how I liked lower bars. I liked 'em fine, but it put the cables in too much of bind. Mainly the clutch cable. It was harder to operate and it also seemed to change the lever position where the clutch engaged/diengaged. I put the stock bars back on - don't have the money I want to spend nor the inclination to change out the cables right now.
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #5 of 12 (permalink) Old 02-14-2008, 04:05 PM
dirtrack650's Avatar
Try the 'superbike' bar. The only thing that can cause a problem is the gas tank getting hit with low bars.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #6 of 12 (permalink) Old 02-14-2008, 04:29 PM
I put some dirt bike handlebars on mine just to see how I liked lower bars. I liked 'em fine, but it put the cables in too much of bind. Mainly the clutch cable. .
You need to re-route the cable, or shorten it. This sometimes is a trial and error thing. I have put lower bars on a few bikes and had to get creative on routing...
post #7 of 12 (permalink) Old 02-14-2008, 06:48 PM
ive been thinkin the same thing for a loooong time. (right now my 750 is in the basement in pieces though)
can we get some pics?
skaere is offline
post #8 of 12 (permalink) Old 02-14-2008, 09:49 PM
You might try bikemaster bars as they are much cheaper than flanders.
jworth is offline
post #9 of 12 (permalink) Old 02-15-2008, 11:34 AM
NO there was no need to shorten the cables as the height and width were near perfect matches for the stock bars.
post #10 of 12 (permalink) Old 02-15-2008, 01:17 PM
BMan23777's Avatar
On mine I had to get creative on re-routing the cables like Knifemaker said.
Brian Manchester
'89 "GRIMM"
04 durango AWD
