k&n air filters - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 02-07-2008, 03:07 AM Thread Starter
Talking k&n air filters
ive seen a few bike with after market k&n fiters on the carbs. the side breather boxes have been taken off. can any one give me the part number of the filters they use to do this.
thanks
evil russ is offline
post #2 of 16 (permalink) Old 02-07-2008, 03:17 AM
ipfreely's Avatar
What you are refering to is called an earshave. Its covered in the Vulcan Verses. The part number you are looking for is K&N RC-2340. When I did mine, there was a place on the net that had them cheaper than local and offered free shipping, but at the moment I dont remember the place. Sorry.
If you are going to do and earshave you are also going to need to re-jet. That is also cover in the verses under earshave.
Kuryakyn Flame Grips
Bar End helmet locks
Chrome / Gold "Live to Ride Mirrors"
Coastered, Shaved & Jetted
K&N Pod Air Filters
KisanTech headlamp & Taillight modulators
Iridium's
Leather Lyke Hard Bags
Voltmeter, Clock
Stebel Nautilus horn
Slipstreamer SS28
J&M CB Radio
Audiovox CCS-100 Electronic Cruise Control
Mustang Seat, Protac Drivers Backrest
And of course the obligatory stator replacement[/FONT]
ipfreely is offline
post #3 of 16 (permalink) Old 02-07-2008, 04:52 AM Thread Starter
thanks for the help and tips
post #4 of 16 (permalink) Old 02-07-2008, 09:22 AM
Scoop's Avatar
I think this is where I got mine. Look to be the same as the K&N but without K&N stamped on the end!
http://www.crc2onlinecatalog.com/pod_filters.htm
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #5 of 16 (permalink) Old 02-07-2008, 10:33 AM
This may sound dumb at this point but... Is the rejeting necessary because of the change in air flow?
Just curious.I understand the "carb" better now, but I'm far from a master.
post #6 of 16 (permalink) Old 02-07-2008, 10:56 AM
As I understand it rejetting is required because you are getting more air into the carbs so you need more fuel as well.
You will also have to adjust the Air/Fuel mixture screws.
JamieB is offline
post #7 of 16 (permalink) Old 02-07-2008, 02:03 PM
Undercover Sportbiker
AJCruzin's Avatar
The need to rejet is to reduce how lean your bike will run. I recently did the ear shave and against the advice of the senior members here have not yet rejetted. I have my mixture screws out about 2.5 turns and she runs good so far. Definitely does not like throttle until she's warm though. I'm taking her for a ride this weekend to see how things go in real world conditions instead of driveway dyno and will make a semi-final decision then.
BTW - if you decide that you don't want to shave but still want K&N's in the ears, I have a nearly new pair for sale...
AJCruzin is offline
post #8 of 16 (permalink) Old 02-07-2008, 02:13 PM
rejet "?"
I too have not rejeted, I would like to but I look at the carbs and it looks like a lot of work. My bike runs very good as it is, however; I can see that my pipes are bluing a sign of lean fuel to air mixture. Maybe later.....
post #9 of 16 (permalink) Old 02-07-2008, 02:42 PM
Well it's a thought then that you could conceivably add a piece of fabric between the filter & the carb then to further reduce the amount of air flow? Thus shave & no re-jetting. If too much air is the reason for jetting, and jetting is the increase of fuel flow. Then it would seem easier to reduce the air flow? What do you think!
post #10 of 16 (permalink) Old 02-07-2008, 02:58 PM
The more air the better, however; you need the right fuel mixture for it run really great.
