vn750 trike....anyone? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 01-08-2008, 02:41 PM Thread Starter
stan's Avatar
I have decided to try to make a trike from scratch. I can buy a good vn750 from a friend( because I don't want to experiment with my pride and joy).
my question...do any of you know someone who has done this to a vn750?
if not I'll blaze new trails
thanks
Stan
VROC #12293
2004 VN750
MSF Ridercoach
new tires (OEM Stones) 6/2008
home made floorboards (knifemakers styling)
stator replaced 6/2008
cobra slashcuts 7/2007
clear alternatives brake & tailight 8/2008
Added Mutazu hard bags 3/2009
added customLED load equalizers for the bags LED lights 3/2009
stan is offline
post #2 of 18 (permalink) Old 01-08-2008, 03:02 PM
I have seen one before. I think it was some kind of kit they used.
With that I should note that the bike had three wheels on the ground, but the bikes original rear wheel was somehow raised up and used just to power the two add ons in the rear.(or that is how it appeared)
Now if you are talking about making a true trike, meaning only using the front frame , motor , etc..and plan on using something of your own design in the rear, you should consider that because the bike is a shaft drive, you will have more obstacales to overcome as opposed to choosing a chain or belt drive bike.
post #3 of 18 (permalink) Old 01-08-2008, 03:51 PM
Scoop's Avatar
KM - Shaft drive might actually be easier - just use a narrowed car rear end from say an old Pinto or 4 cyl Mustang or some old RWD Japanese car. Just adapt the driveshaft to the rear end u-joint. Should be fairly easy to do.
Stan - Awesome idea! Keep us posted.
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #4 of 18 (permalink) Old 01-08-2008, 04:43 PM
dirtrack650's Avatar
I've seen Pinto's and Maverick's used on Wings, nothing as small as our VN's
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #5 of 18 (permalink) Old 01-08-2008, 05:02 PM
HAWK
Ccspinner's Avatar
There was one done in England I saw picts, let me see if I can find them.
Here it is http://hometown.aol.co.uk/teasyandjill/index.html
Hope this helps.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #6 of 18 (permalink) Old 01-08-2008, 05:39 PM
I posted this one here about a year ago....
(there's also a pic of a 500 trike in the post HERE)
Nothing was known about it though except for this......
This is my 2004 Kawasaki 750 Vulcan with a '74 Dodge Colt 411 rear end inverted. Very clean and custom. Not cluttered with cargo compartments. Rear suspension includes two swing arms. Custom seat, Dual front disc brakes, rear brake drums.
post #7 of 18 (permalink) Old 01-08-2008, 07:01 PM
Scoop's Avatar
Wow - both of those turned out really nice.
97 VN 750
R&R Relocated
Degoated
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
Scoop is offline
post #8 of 18 (permalink) Old 01-09-2008, 08:24 AM Thread Starter
stan's Avatar
KM, the kit you saw was a voyager kit. you make no mods to the bike with that kit and can go from 2 wheel to four in minutes.
I am going to do a true trike conversion. I agree with scoop, I think it'll be easier to use a shaft drive bike and mod the ujoint.
hyper and ccspinner, thanks for the pictures. I'm sure they will help. the donor bike I am going to use is a 2000 with 14K on it. I bought it for $1,500 so I didn't pay a lot for the basic bike.
now to hit autocad and come up with my concept. BTW, I can come up with a miata rear end for free so I'm going to see if that'll work
VROC #12293
2004 VN750
MSF Ridercoach
stan is offline
post #9 of 18 (permalink) Old 01-09-2008, 10:00 AM
1980s toyota starlets are even smaller
coyote is offline
post #10 of 18 (permalink) Old 01-09-2008, 10:55 AM
Scoop's Avatar
Note that the comments on Hyper's post said the rear was inverted. This must mean that the drive shaft on a VN750 turns the opposite direction from a standard car and you will need to flip the rear end over (unless you prefer to drive it backwards!). You'll need to account for proper pinion bearing oiling if you do that. Sometimes you can just install an internal oil slinger, but it will depend on the rear end you ultimately get. I am not familiar with Miatas.
97 VN 750
R&R Relocated
Degoated
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
Scoop is offline
