Visible rust when I open gas cap - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 08-02-2014, 07:12 PM Thread Starter
CBH
CBH's Avatar
Its not chunky or flaking off, just looks miscoloured. Do I need to be concerned and to fix it do I really need to remove the tank?
1985 750 Vulcan-Red
36,875 miles
New timing chain
New choke cable
Clean front rim
new throttle pull back cable
new spark plugs
New Bridgestone on the back
New Fluids all around
SeaFoam in the tank
CBH is offline
post #2 of 4 (permalink) Old 08-02-2014, 07:17 PM
Kawasakiman's Avatar
You may have to remove the tank since gas does not mix well with any kind of rust. It would kill the bike
Can I get a hell to the yeah for all the bikers out there?!?!?!
-LeatherLyke Saddlebags
-Extended Backrest
-Fire and Steel Engine Guard
-Relocated Turn Signals
-New Toolbox Cover
-Brand New Battery
-21,500 Miles, TIME TO RIDE!!!!
Kawasakiman is offline
post #3 of 4 (permalink) Old 08-03-2014, 02:51 AM
post up a pic my tank has a rust color to it and has been that way for a year or so and i have had no issue with it but i cant tell you your will be the same with out a pic
post #4 of 4 (permalink) Old 08-03-2014, 08:17 AM
2000 VN 750 Senior Member
I would just keep an eye on it. If it is only discoloration at this point there should not be a problem. You could drain some fuel periodically from the tank via the hoses and check for debris. If there is any contamination you then should react. You could also install a small clear fuel filter in the line so you have an easier method of watching any progress of the potential rust situation reaching your carbs. Good luck and let us know your choice and the future situation if it progresses.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
