Where to start - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 12-20-2007, 10:36 AM Thread Starter
Where to start
Hey all
I brought my 750 home and the seat, tank, and some of the plumbing were removed. I was told that when the bike was together it would start but not run. Any suggestions on how/where to start to get her going? I'd love to get her going over the winter so she'll be ready to ride when it gets nicer out.
Thanks in advance for your help and suggestions,
Truckie
truckie453 is offline
post #2 of 7 (permalink) Old 12-20-2007, 11:02 AM
Search Goddess
Dianna's Avatar
Well that's not much to go on...
Start but not run?
The fact that it will supposedly start says the electrical may be ok, but if they mean "not run" in that it may eventually die, then it could be a stator problem.
So.. where to start.. put the bike back together and see what it does do then. With a charged battery, enough fuel to do some tests and all other fluids filled turn the key..
Does it start but sputters? Could be the carbs need cleaning or maybe as simple as one of the floats or needles are stuck.
Without more to go on it's hard to suggest where to start other then.. get it started
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #3 of 7 (permalink) Old 12-20-2007, 11:51 AM
Crobins365's Avatar
I second that. Get all her pieces back on her and then see what happens with fuel, spark, and compression(hopefully). Do you have a Service Manual or the Clymer's?
C
Crobins365 is offline
post #4 of 7 (permalink) Old 12-20-2007, 12:21 PM Thread Starter
Thanks for the quick replies... I guess "get it started" is the way to go.
I do have the Clymers and a somewhat warm shed, it's gonna be a long winter
post #5 of 7 (permalink) Old 12-20-2007, 03:55 PM
oglejust's Avatar
i would 1st make sure its getting spark. then see if it'll start. if not its most likely a timing problem or a fuel problem.
.... slightly modified
oglejust is offline
post #6 of 7 (permalink) Old 12-20-2007, 04:44 PM
Crobins365's Avatar
If you're in the Northeast, it's probably already been a long winter, huh? Good winter for wrenching! And lots of knowledgeable folks here on the Forum, most of whom will be wrenching a bit during the cold weather, too. DOn't hesitate to ask any questions - someone here will know the answer!
post #7 of 7 (permalink) Old 12-20-2007, 08:45 PM
Geek
rnewell's Avatar
If this bike has been sitting for a while drain the gas from the tank and carbs, and get some fresh gas.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
