loud pipes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 07-23-2014, 06:18 PM Thread Starter
loud pipes
I drilled holes in the back plates of my pipes to make it louder.. after I rode it for 45 minutes.. It wanted to stall.. and now it won't idle.. It dies if I let the RPMs go less that 3000... did I **** my bike up by doing that?
Grace is offline
post #2 of 13 (permalink) Old 07-23-2014, 06:31 PM
Dr. Vulcanstein
jadabull's Avatar
I don't know, did you? More info needed....how many holes, what diameter? still have goats belly, stock intake? Might need a carb adjustment or could be an unrelated problem.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #3 of 13 (permalink) Old 07-23-2014, 06:37 PM Thread Starter
10 holes... 3/8's... still has goats belly..
Grace is offline
post #4 of 13 (permalink) Old 07-23-2014, 06:39 PM Thread Starter
The bike has always been a bit hard to idle and restart after a ride longer than 45 minutes.. I wonder if the goats belly is heating up the electronic components ..
Grace is offline
post #5 of 13 (permalink) Old 07-23-2014, 06:45 PM
Dr. Vulcanstein
jadabull's Avatar
Most that I've seen people do is 8 holes and I believe 6 holes is most common. Probably should have gotten the rough idle issue taken care of then drill the baffles, just to make it easier to tune. Folks have claimed the goats belly caused their r&r to overheat. Mine is stock intake/exhaust 93' no problems.
..( ___/\ /))
.( l vv/ )(
.) \ O/ )((
jadabull is offline
post #6 of 13 (permalink) Old 07-23-2014, 09:24 PM
hot starting issues can also be tied to the pick coil gap. there is an easy mod to allow making the gap .020 and it helps a lot in hot start, and possibly could also help a hot idle problem.
but charging system needs to be working properly as well. as mentioned, the goats belly has been reported to cause issues with the R/R getting too hot.
Also, AGM batteries are recommend for these bikes.. can help a lot of starting or other electrical issues
michiganteddybear is offline
post #7 of 13 (permalink) Old 07-23-2014, 09:33 PM
was gonna recommend an agm
post #8 of 13 (permalink) Old 07-24-2014, 12:18 AM
I know my 800 was lean to start with. If you give it more air without more fuel it may get pretty lean
Kenny
Merc
2000 Vulcan Drifter 800
Roadhouse classic 2 > 1 exhaust
Okie Smokie intake config
Changed jets
52K miles or so, always going up
Corbin Seat
Painted flat black winter '12
Mercury is offline
post #9 of 13 (permalink) Old 07-24-2014, 08:26 PM
Open up the low idle mixture screws 1/2 to 3/4 turn ans see if it helps....check yer tank vents too.....if the tank aint venting, it will cause hard starts, and lean runnin....
post #10 of 13 (permalink) Old 07-25-2014, 02:32 PM
IF it was running right before you drilled the holes, you likely leaned it out too much. Turning the pilot screws out might help, but there is a possibility you might have to rejet. When I installed aftermarket pipes on mine, it was way lean, I had to go up one size on both the main and pilot jets.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
