Elec. ??? Headlight Toggle Switch--- - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 12-10-2007, 05:21 PM Thread Starter
Question Elec. ??? Headlight Toggle Switch---
Why did I ask ????????? Let me reword it, I want to put a toggle switch on my headlight so I can signal my girl friend..OK... Put it on the hot wire or ground wire ???
Thanks...Old Dog...
post #2 of 15 (permalink) Old 12-10-2007, 06:08 PM
Get a battery tender and plug it in for the winter. Also use "Stabil" fuel additive to keep the gas fresh. If you want to run it without the lights pull left side cover; remove the headlight and running light fuses.
Too cold and wet to ride here.
Thediode
thediode is offline
post #3 of 15 (permalink) Old 12-10-2007, 07:50 PM
Once Banned
cegodsey's Avatar
I vote for the tender as well. It's a good investment. Unless something has changed over the last year, get some Seafoam and put that in your tank. I've heard a few complaints on this board about Stabil.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #4 of 15 (permalink) Old 12-10-2007, 08:37 PM
Well, if you're out on the public roads, you don't want to run without the headlight.
Tenn. laws requires you to run with the headlight on.
You can check out the other Tenn. state motorcycle laws at the AMA site, HERE.
post #5 of 15 (permalink) Old 12-10-2007, 10:43 PM
HAWK
Ccspinner's Avatar
I would use a relay and put it on the ground side, IF you just want to use a switch make sure it is strong enought to handel the amp draw, you dont want a switch to fail and cause your headlight to go out.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #6 of 15 (permalink) Old 12-10-2007, 11:01 PM Thread Starter
Thanks Ccspinner;
I have a 10 amp on hand, would that be enough or should I get a higher amp switch..???
post #7 of 15 (permalink) Old 12-10-2007, 11:22 PM
HAWK
Ccspinner's Avatar
10 Will work on low beam but not on High, the stock fuse is 10 for the low headlight. As long as you have not upped the bulb to a larger one.
Chad Falstad "Hawk"
Vroc #17649
post #8 of 15 (permalink) Old 12-11-2007, 12:08 AM
Scoop's Avatar
Thanks...Old Dog...
OK . . . So tell us about your girl friend!
97 VN 750
R&R Relocated
Degoated
Ears Shaved/Rejetted
MF/AGM Battery
Irridium Plugs
Spring Solo Seat
32 Ford Model A Tail Light
Rear bobbed and hard-tailed!
Scoop is offline
post #9 of 15 (permalink) Old 12-11-2007, 01:34 AM
Once Banned
cegodsey's Avatar
Girl friend? You shoulda just said so. No reason to be bashful here. Otherwise we'll give you the run around suggesting you do just about everything else!
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #10 of 15 (permalink) Old 12-11-2007, 01:57 AM
Thanks...Old Dog...
Couldn't you like take your hat and cover the light for a bit and than uncover it again, giving it the on and off effect???
If you inssist on a switch I would put it on the ground side. The ground is common to both high and low beam.
